I've noticed that arm gcc, when compiling code for Cortex-M0 (at least) seems to generate instructions:
adds r0, r2, #0
Where I'm pretty sure that it the same as:
movs r0, r2
In fact, I can disassemble a relatively substantial program and not find a single register/register "mov" or "movs" instruction (for r0..r7)
is there some reason for this?
MOVS r0, r2 is the same as LSLS r0, r2, 0 according to UAL syntax.
ADDS with zero was emitted by early Thumb-1 compilers, so GCC should ideally be updated as it makes disassembly harder to read.
Note it's generally best to report issues like this in the GCC bugzilla
Wilco
View all questions in GNU Toolchain forum
