How to boot bare-metal binary on Corelink SGI-575?
I'm trying to boot a simple binary on SGI-575 but unable to get expected result. To load and run application, I used following commands:
# When load address is 0x00000000
$ ./FVP_CSS_SGI-575 -a css.cluster0.cpu0=/home/user/DS-5-Workspace/HelloWorld-575/HelloWorld.axf
terminal_uart_aon: Listening for serial connection on port 5000
terminal_uart0: Listening for serial connection on port 5001
terminal_uart1: Listening for serial connection on port 5002
terminal_uart_ap: Listening for serial connection on port 5003
terminal_uart1_ap: Listening for serial connection on port 5004
terminal_s0: Listening for serial connection on port 5005
terminal_s1: Listening for serial connection on port 5006
terminal_mcp: Listening for serial connection on port 5007
terminal_0: Listening for serial connection on port 5008
terminal_1: Listening for serial connection on port 5009
Warning: Failed to write bytes at address range [0x00020000..0x00044FFF] when loading image "/home/user/DS-5-Workspace/HelloWorld-575/HelloWorld.axf".
Simulation is started
WARNING: Access to reserved memory region: Write 4 bytes 0x0 to 0xe7fefff0. Aborting.
WARNING: Access to reserved memory region: Write 4 bytes 0x0 to 0xe7fefff4. Aborting.
WARNING: Access to reserved memory region: Write 4 bytes 0x0 to 0xe7fefff8. Aborting.
WARNING: Access to reserved memory region: Write 4 bytes 0x0 to 0xe7fefffc. Aborting.
WARNING: Access to reserved memory region: Write 4 bytes 0x0 to 0xe7ff0000. Aborting.
WARNING: Access to reserved memory region: Write 4 bytes 0xffffffff to 0xe7ff0004. Aborting.
WARNING: Access to reserved memory region: Write 4 bytes 0xe800e800 to 0xe7ff0008. Aborting.
WARNING: Access to reserved memory region: Write 4 bytes 0x0 to 0xe7ff000c. Aborting.
# When load address is 0x80000000
$ ./FVP_CSS_SGI-575 -a css.cluster0.cpu0=/home/user/DS-5-Workspace/HelloWorld-575/HelloWorld.axf --start css.cluster0.cpu0=0x80000000
Warning: Failed to write bytes at address range [0x80000000..0x8000493F] when loading image "/home/user/DS-5-Workspace/HelloWorld-575/HelloWorld.axf".
Warning: Failed to write bytes at address range [0x80004940..0x80044FFF] when loading image "/home/user/DS-5-Workspace/HelloWorld-575/HelloWorld.axf".
I also tried it using DS-5 Debugger. Although it doesn't give any warning related to binary loading as in previous case but still it doesn't show any progress related to execution. Initially PC is at 0x0 and no break point hits after I press start button (Not even break point at 0x04). Pressing pause button or sending interrupt through debugger causes cores to power down.
Does anyone have idea what I'm missing or doing wrong?
