I am so new ARM Community and I am M.Sc. student. I need to download FVP_Base AEMv8A-AEMv8A for my academic researching. I think, in this FVP there is no LCD lock. Because I am working on OPTEE secure displaying. But I can't find it. Can you show how to do that?
Hi tesmnorth,
I have moved your question to the Arm Development platforms community as they may be best placed to answer your question.
Please download the FVP from https://developer.arm.com/products/system-design/fixed-virtual-platforms
I am the same question with tesmnorth, I view this website many times, but I haven't get a link to download FVP_Base AEMv8A-AEMv8A
As mentioned above the link to start from is https://developer.arm.com/products/system-design/fixed-virtual-platforms
You will need an account on developer.arm.com
Find the User Menu on the top right-hand corner of the page and click register. Follow the registration process and make note of your login credentials.
Find the Armv8-Base Platform FVP. This is a dual cluster (8 core) FVP. The current filename is FM000-KT-00173-r11p4-37rel0.tgz but it will change as new releases are made.
Thank you Jason Andrews I find Armv8-Base Platform FVP and Armv8-A Foundation Platform
Is Armv8-Base Platform FVP the same as FVP_Base AEMv8A-AEMv8A?
Glad you found it. Yes, those two things are the same. There are many versions of "FVP Base" with different CPU types, but the Armv8 Base uses the Architecture Envelope Model (AEM) with 2 clusters. There are also versions of FVP Base which use other a Cortex-A CPU models.
Je pense que dans ce FVP, il n'y a pas de verrouillage de l'écran LCD. Parce que je travaille sur l'affichage sécurisé OPTEE.
View all questions in Arm Development Platforms forum
