Hi experts Ash WildingMark Nicholson Michele Wilkinson,
I configured my Juno board as this instruction and my workspace is initialized by the script from that page too.
Now I met some unknown issues when setting secure timer for my board. I find the ARM-TF provides a test secure payload and they utilize the secure timer so I want to try this payload to confirm my board's timer works well.
In this case, I'm wondering can I still use the workspace I got to build the TSP for Juno board?
If I can, could you please give me some hints about how to modify the build scripts? If I can't, is there any other instructions about applying the TSP on Juno?
Thank you in advance.
Simon
Hi Simon,
I had a quick bash at getting this to work with the existing workspace and this is what I came up with:
1) Sync 64-bit Juno build from source Linux/Android workspace
2) Build everything using `./build-scripts/build-all.sh all'
3) Clean ARM Trusted Firmware:
$ cd arm-tf/ $ make realclean
4) Create a build wrapper for ARM Trusted Firmware like this:
#!/usr/bin/env bash CROSS_COMPILE=/path/to/gcc/bin/aarch64-elf- \ make PLAT=juno DEBUG=1 \ BL33=<workspace>/output/juno/components/juno/uboot.bin \ SCP_BL2=<workspace>/output/juno/components/juno_SILICON/scp-ram.bin \ SPD=tspd \ all fip
And run it.
5) Erase the Juno's Flash
6) Mount the Juno's SD card, then delete everything off it
7) Copy contents of `<workspace>/recovery/' onto Juno's SD card
8) Copy contents of `<workspace>/output/juno/juno-busybox/uboot/' to the `/SOFTWARE/' folder on the Juno's SD card
9) Copy these two files to the `/SOFTWARE/' folder on the Juno's SD card:
<workspace>/arm-tf/build/juno/debug/bl1.bin <workspace>/arm-tf/build/juno/debug/fip.bin
10) Issue a `sync' command on your host PC
11) Reboot the Juno
A few things to note:
Also you may want to automate the copying of the components on to the SD card as it's a bit cumbersome.
Hope that helps,Ash.
Hi Ash,
For the script you provide, should I put the script under <workspace>/arm-tf and run it?
Also, does the
Ash Wilding said: CROSS_COMPILE=/path/to/gcc/bin/aarch64-elf- \
Again, thank you for the instructions.
The script works for me too! Thanks.
However, I meet another issue after applying TSP and I think maybe you know the answer.
Now after I configure the board with non-secure OE + TSPD + TSP, the above UART covers all message from NS and bottom UART only prints the NOTICE / INFO message from EL3.
In this case, I can't see any print information form TSP itself. If you know how to solve this issue or where should I take a look, please let me know.
Thank you for your help!
Best regards,
It looks like the UART is being misconfigured on Juno.
If you navigate to `<workspace>/arm-tf/include/plat/arm/board/common' and apply these 2 patches you'll see the TSP printing messages to UART1 (the bottom UART) as expected:
v2m_def.patch board_css_def.patch
For example:
NOTICE: TSP: v1.3(debug):v1.3-567-g3fb340a-dirty NOTICE: TSP: Built : 11:54:01, Aug 7 2017 INFO: TSP: Total memory base : 0x4001000 INFO: TSP: Total memory size : 0xa000 bytes INFO: ARM GICv2 driver initialized INFO: TSP: cpu 0x80000100: 1 smcs, 1 erets 1 cpu on requests INFO: TSP: cpu 0x80000000 turned on INFO: TSP: cpu 0x80000000: 1 smcs, 1 erets 1 cpu on requests INFO: TSP: cpu 0x80000001 turned on INFO: TSP: cpu 0x80000001: 1 smcs, 1 erets 1 cpu on requests INFO: TSP: cpu 0x80000101 turned on INFO: TSP: cpu 0x80000101: 1 smcs, 1 erets 1 cpu on requests INFO: TSP: cpu 0x80000102 turned on INFO: TSP: cpu 0x80000102: 1 smcs, 1 erets 1 cpu on requests INFO: TSP: cpu 0x80000103 turned on INFO: TSP: cpu 0x80000103: 1 smcs, 1 erets 1 cpu on requests INFO: TSP: cpu 0x80000100: 2 smcs, 2 erets 1 cpu suspend requests INFO: TSP: cpu 0x80000001: 2 smcs, 2 erets 1 cpu suspend requests INFO: TSP: cpu 0x80000100 resumed. maximum off power level 0 INFO: TSP: cpu 0x80000100: 3 smcs, 3 erets 1 cpu suspend requests INFO: TSP: cpu 0x80000001 resumed. maximum off power level 0 INFO: TSP: cpu 0x80000001: 3 smcs, 3 erets 1 cpu suspend requests INFO: TSP: cpu 0x80000101: 2 smcs, 2 erets 1 cpu suspend requests INFO: TSP: cpu 0x80000001: 4 smcs, 4 erets 2 cpu suspend requests INFO: TSP: cpu 0x80000102: 2 smcs, 2 erets 1 cpu suspend requests
I'll poke the ARM Trusted Firmware development team about this to see whether it's a known issue.
Ta,Ash.
The patches work for my Juno r1 board, thank you Ash!
Great :-)
Sorry for my many questions.. I was testing the TSP functions this morning, at first it all works okay for me.
However, for some unknown reason, now when I copy the new-build fip.bin into the board, I always got the error:
cp: cannot create regular file '/media/simonwan/ARM/SOFTWARE/fip.bin': Read-only file system
I'm still trying to figure it out but I don't find any useful command to solve the issue yet.
If you know how to solve this, please let me know, thank you!
Sounds like you'll need to reformat the Juno's SD card, for example:
$ lsblk$ sudo mkfs.vfat /dev/sdX
(Replacing `/dev/sdX' with the device label corresponding to the Juno's SD card)
Then copy across the deliverables as normal.
Hi Ash Wilding,
I just met a problem about this issue again, could you please take a look?
Today I used the script from this link to get the latest OE-LAMP workspace and I want to use TSP with it. I used the script with the following configuration:
[64-bit] Juno Build from source Linux/Android lsk-4.4-armlt -- Supports Android OpenEmbedded LAMP -- 17.01
The workspace can be builtt. Both OE-LAMP and OPTEE secure payload are running on my Juno board normally.
However, when I tried to use TSP instead of OPTEE as you mentioned above ( I also patched 2 UART patches you shared), the booting will be stuck after these outputs:
Peripheral ID6:0x00000005 Peripheral ID7:0x000000B1 Programming NOR Flash PCIE clock configured... Testing motherboard interfaces (FPGA build 118)... SRAM 32MB test: PASSED LAN9118 test: PASSED KMI1/2 test: PASSED MMC test: PASSED PB/LEDs test: PASSED FPGA UART test: PASSED PCIe init test: PASSED PCIe MAC addresss 0002-F700-62E8 MAC addrs test: PASSED SMC MAC address 0002-F700-62E7 Setting HDMI0 mode for SVGA. Setting HDMI1 mode for SVGA. SoC SMB clock enabled. Testing SMB clock... SMB clock running Releasing system resets... UART0 set to SoC UART0 UART1 set to SoC UART1
I guess it's still something configured wrong with TSP or TSPD while I don't figure it out yet. If you know what's the problem or which part should I check for, please let me know.
Thank you!
Please can you try building ATF -without- the UART changes, and instead take the cover off your Juno and connect to FPGA UART0 (the J55 header), and see whether that works?
I'll try as soon as I get the office. However, I'm still wondering why for the OPTEE case the booting can run normally while the TSP cannot?
Hi Simon, I'm away from the office myself without physical access to a Juno board for the next ~week, so am limited in how much I can investigate this. I'll take a look when I can, though.
Hi Ash, would you get a chance to look into the case this week? I tried to open my Juno box while I don't find the FPGA UART port so I think it's better for me to just configure the TSP with SoC UARTs, thank you.
I think it would be wise to take this to a private case: please can you send an email to juno-support@arm.com and I'll pick it up.
Please do keep in mind, though, that this is starting to fall out of scope of what we officially support and so I may be limited in how much I can help you.
The problem you are experiencing is due to the recent changes to the way the deliverables communicate with the SCP - via SCMI rather than SCPI (see the Release Notes).
To fix this you need to build Trusted Firmware with the `CSS_USE_SCMI_SDS_DRIVER=1' flag set, i.e.:
CROSS_COMPILE=../gcc/bin/aarch64-linux-gnu- \ make PLAT=juno DEBUG=1 LOG_LEVEL=40 \ BL33=../out/SOFTWARE/bl33-uboot.bin \ SCP_BL2=../out/SOFTWARE/scp_bl2.bin \ CSS_USE_SCMI_SDS_DRIVER=1 \ SPD=tspd \ all fip
This will let you successfully boot when using the Linaro Release 17.07 board files.
To see the TSP output, attach an RS232 10-pin to DB9 connector to the J55 header on your Juno:
The UART uses the same 115200 8N1 setup as the main UARTs on the back of the board. You should see messages like this printed there:
INFO: TSP: cpu 0x80000100: 340 smcs, 340 erets 170 cpu suspend requests INFO: TSP: cpu 0x80000100 resumed. maximum off power level 1 INFO: TSP: cpu 0x80000100: 341 smcs, 341 erets 170 cpu suspend requests INFO: TSP: cpu 0x80000100: 342 smcs, 342 erets 171 cpu suspend requests INFO: TSP: cpu 0x80000100 resumed. maximum off power level 1 INFO: TSP: cpu 0x80000100: 343 smcs, 343 erets 171 cpu suspend requests INFO: TSP: cpu 0x80000100: 344 smcs, 344 erets 172 cpu suspend requests INFO: TSP: cpu 0x80000100 resumed. maximum off power level 1 INFO: TSP: cpu 0x80000100: 345 smcs, 345 erets 172 cpu suspend requests INFO: TSP: cpu 0x80000100: 346 smcs, 346 erets 173 cpu suspend requests INFO: TSP: cpu 0x80000100 resumed. maximum off power level 1 INFO: TSP: cpu 0x80000100: 347 smcs, 347 erets 173 cpu suspend requests INFO: TSP: cpu 0x80000100: 348 smcs, 348 erets 174 cpu suspend requests
Thank you very much, Ash! I think I can get the correct output now. I'm sorry that I don't see the last message about sending email to the support team. Have a good day.
No problem at all, glad to be of help :)
View all questions in Arm Development Platforms forum
