Hi there,
After setting up the board followed by the instruction, I connect both UART ports with my computer. For my board one port shows normal world output while other one shows OP-TEE output.
In this case, I'm wondering is there anyway for me to print some information with the code running in the trusted firmware layer?
I see the header stdio.h in the lib folder contains one printf function. However, after calling this function, I don't see any output from either UART port.
Thank you in advance.
Simon
I don't know without checking & this is only a guess, but...
It might be worth looking at either the LOG_LEVEL compiled into the build and associated with your messages. See LOG_LEVEL here: https://github.com/ARM-software/arm-trusted-firmware/blob/master/docs/user-guide.rst
Also check the library function and see which physical UART the pritnfs are ultimately going to (based on the address)
MarkN
View all questions in Arm Development Platforms forum
