uncaught warning in ARM compile
I use python language to call ARM compile as below.
status = os.system(buildCommandLine)
if status:
print 'error!!'
But, above status did not catch an warning #550-D. e.g.) Warning: #550-D: variable "abcd" was set but never used
Can I get how to catch any warning error during compile error?
  • Hello,
    You're more likely to get an answer for this in one of the other Communities such as Software Tools.
    With that said, am I right in thinking you're using ARM Compiler / Keil?
    If so and your test condition is based on the compiler returning a non-zero value being equivalent to an error, you could pass the flag --diag_error=warning flag which will treat all warnings as errors; this will abandon the compilation and cause a non-zero value to be returned.
    Hope that helps,
    Ash.
  • Hello,
    Hope that helps,
    Ash.
