OPTEE 2.0 tee-supplicant issue
Hi experts,
Today I was trying to use the latest OPTEE version to replace my previous one (v1.1.0) on my Juno board and I met one issue about tee-supplicant.
I used the initialization script from ashwildingarm 's post with the choice "Juno, latest, openembedded".
Now I have booted up my board with the new system.
I could successfully run the command modprobe optee_armtz while I got the error -sh: tee-supplicant: command not found when I was trying to use the command tee-supplicant &.
Is there anything I missed for running tee-supplicant?
By the way, now I'm following the instruction of optee_test for running TA.
If you have any other document about running a TA / xtest on latest OPTEE, please let me know so I could check the document by myself.
Thank you.
Simon
