I have an ARM JUNO card and i want to install OP-TEE on it.
I'm using the Linaro last deliverable to boot up. Then i installed a Debian on it. However the packages like libc6:i386 are not available on it which make the setup impossible.
Can anyone help me on it ? Is it better to use an other Linux distribution ? If the response is yes, can you please indicate me the necessary steps to install OP-TEE on Juno starting from the scratch.
Best Regards.
libc6:i386
This would be for the Intel i386 32-bit architecture, which won't work on your Juno. I'm guessing you're trying to install some 32-bit libs in the same way you would on a 64-bit PC? If so,on your Juno the 64-bit architecture is arm64 and the 32-bit architecture is armhf, so in your case you'd actually want to install libc6:armhf.
You may need to add armhf as a supported architecture to dpkg, just like you would add i386 on a 64-bit Intel / AMD machine.
Do this to check whether armhf is supported:
$ dpkg --print-foreign-architectures
If it's not listed, add it:
$ sudo dpkg --add-architecture armhf$ sudo apt-get update
And then you can try to install the 32-bit library again, as libc6:armhf
Hope that helps.
View all questions in Arm Development Platforms forum
