ARM JUNO BOARD R2
     i am very new to ARM JUNO R2, below are my doubts regarding R2.
  1. How to generate the image for Juno board
  2. what are the images we will get after compilation, how to load the images into target board .
  3. Description about each image and what are all the peripherals is initialized by each image
  4. when board is powered on, how will be the boot flow. where user has control to load the application image .
Regards,
Murali
9092838830
  • Hello,
    There's a lot of information on connected Community (CC) that might help you. Look at the Instructions for Using the Linaro deliverables and FAQs on these pages. Also refer to this Getting Started Guide (referenced from the CC pages). http://infocenter.arm.com/help/topic/com.arm.doc.den0928f/DEN0928F_juno_arm_development_platform_gsg.pdf
    Some brief responses, these are very "open" questions...
    There are GCC cross compilers referenced from the standard instructions. There's also an FAQ on developing baremetal code (running post Trusted Firmware). The supplied OE LAMP stack for Juno also includes a cross compiler so you can natively build Linux apps.
    It depends how and what you are building (see above). Baremetal code development is going to typically rely on a JTAG debugger to allow you to load code directly into RAM and then debug it. If you are working on top of Linux, you have many more options  (e.g. can simply mount a remote drive or use something like SCP to copy things across and debug remotely via GDBserver).
    See the Getting Started Guide above & also the external Trusted Firmware (TF) documentation.
    It depends: Some basic peripherals (DDR for example) are configured in the early boot stages of TF. Some peripherals (Ethernet) are configured by drivers later in the SW stack.
    By default a single lead CPU will boot - other CPUs will be woken by Linux.
    HTH
    MarkN.
  • Hello,
    HTH
    MarkN.
