I am using Juno-R1 board with Linaro Release 16.02 Latest (juno-oe).
I can put Juno into system suspend, but can't resume as it is the suspend state forever.
Running the following command :
# echo +5 > /sys/class/rtc/rtc0/wakealarm
# echo mem > /sys/power/state
Also in the case of kernel removing PCI endpoint Device Driver (SATA controller and GbE controller) ,
though Juno could resume, it output ERROR log as follows :
pcieport 0000:01:00.0: Refused to change power state, currently in D1
pcieport 0000:02:02.0: Refused to change power state, currently in D1
pcieport 0000:02:01.0: Refused to change power state, currently in D1
pcieport 0000:02:03.0: Refused to change power state, currently in D1
pcieport 0000:02:10.0: Refused to change power state, currently in D1
pcieport 0000:02:0c.0: Refused to change power state, currently in D1
pcieport 0000:02:1f.0: Refused to change power state, currently in D1
pci 0000:03:00.0: Refused to change power state, currently in D1
pci 0000:08:00.0: Refused to change power state, currently in D1
What could be happening?
I would appreciate any suggestions or information.
Thank you.
Hi taken,
As I mentioned in https://community.arm.com/thread/9687,
once you disable sky2 ethernet driver you will start seeing PCIe warnings
in the resume path. I just gave the suggestion as workaround for time being
in case you are blocked for any non-PCIe work + suspend to RAM.
I am still looking at this issue and will get back to you once I have any
further information.
Regards,
Sudeep
Hi Sudeep,
I'm sorry for my late reply.
Thank you for your response.
I wanted more information to use PCIe + suspend to RAM and contributed this discussion.
I will be waiting for your further information.
View all questions in Arm Development Platforms forum
