Hi There,
We have V2S-A53x2 tile on VersatileExpress board. It failed to boot and we got the message below. It is appreciated if any guidance. Thanks!
Programming NAND from \SITE2\HBI0247C\SMMA53\a53_b00.bit
Percentage complete:100% (0 bad pages)
Starting NAND bytestreamer...
ERROR: Bytestreamer failed.
Verifying NAND from \SITE2\HBI0247C\SMMA53\a53_b00.bit
ERROR: FPGA failed to configure but NAND verify passed.
Please update the bit file image as it could be corrupted
or set UPDATE: TRUE in config.txt to re-format the NAND
ERROR: DB2.0 DCC 0 FPGA 0 SPI configuration failed.
Best Regards,
Jianle
Hi Jianle,
This is probably not an issue of wider interest to connected community users.
I believe you have raised a case with support with regards to this issue, in which case we will help you through our support interface.
If you have not already raised a support case then please let me know!
kind regards
Michele
Got it. Thanks!
/Jianle
View all questions in Arm Development Platforms forum
