How to access a physical address which is larger than 4G in Trusted firmware provided by Linaro
I am using Trusted Firmware Image(LSK and Android filesystem) provided by Linaro on Juno board r1. In my case, I just want to some trivial test in EL3, e.g., reading specific memory.
To make things easier, I didn't do anything until the system is completely booted. Then I load a kernel module which sends a SMC instruction and the SMC exception will be handled in BL3-1 by a custom handler. In the handler, I disabled MMU for EL3 and attempted to access a physical address directly. But I found that if the physical address is larger than 0xffffffff(4G), the content I got will be all 0. The physical address lower than 0xffffffff works perfectly. And If I mapped that physical address into a virtual address smaller than 0xffffffff(Linaro's EL3 only support virtual address lower than 0xffffffff), it also works.
So, why I can not get the correct content of a physical address larger than 0xffffffff after I disabled MMU in EL3?
Is there anyone know the details?
Thanks a lot for helping me!
