Problem with ARM Juno first boot
i want to use an ARM Juno i have. Unfortunately, when i plug a USB 3.0 usb stick with ext3/ext4 format i have the following traces :
ext4 :
[ 4.004845] sda: sda1
[ 4.009631] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 4.072965] EXT3-fs (sda1): error: couldn't mount because of unsupported optional features (240)
[ 4.084337] EXT2-fs (sda1): error: couldn't mount because of unsupported optional features (240)
[ 4.110636] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 4.118262] VFS: Mounted root (ext4 filesystem) readonly on device 8:1.
[ 4.126529] devtmpfs: error mounting -2
ext3 :
[ 3.555042] sda: sda1
[ 3.561781] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.655607] kjournald starting. Commit interval 5 seconds
[ 3.655935] EXT3-fs (sda1): mounted filesystem with writeback data mode
[ 3.655965] VFS: Mounted root (ext3 filesystem) readonly on device 8:1.
[ 3.657694] devtmpfs: error mounting -2
Can anyone help me to boot up my ARM Juno card please.
Thank you very much
PS : I took two different usb sticks. 1 transend and 1 sandisk with the same problems
