Compiling Xen for Juno
I am trying to run Xen on Juno r0 board and while compiling the Xen code getting following error -
make xen XEN_ARCH_TARGET=arm64 debug=y CONFIG_EARLY_PRINTK=juno
make -C xen install
make[1]: Entering directory `/home/nishaj/Xen/xen/xen'
make -f Rules.mk _install
make[2]: Entering directory `/home/nishaj/Xen/xen/xen'
make -C tools
make[3]: Entering directory `/home/nishaj/Xen/xen/xen/tools'
make symbols
make[4]: Entering directory `/home/nishaj/Xen/xen/xen/tools'
make[4]: `symbols' is up to date.
make[4]: Leaving directory `/home/nishaj/Xen/xen/xen/tools'
make[3]: Leaving directory `/home/nishaj/Xen/xen/xen/tools'
make -f /home/nishaj/Xen/xen/xen/Rules.mk include/xen/compile.h
make[3]: Entering directory `/home/nishaj/Xen/xen/xen'
Xen 4.6-unstable
make[3]: Leaving directory `/home/nishaj/Xen/xen/xen'
[ -e include/asm ] || ln -sf asm-x86 include/asm
[ -e arch/x86/efi ] && for f in boot.c runtime.c compat.c efi.h;\
  do ln -nsf ../../../common/efi/$f arch/x86/efi/; done;\
  true
make -f /home/nishaj/Xen/xen/xen/Rules.mk -C include
make[3]: Entering directory `/home/nishaj/Xen/xen/xen/include'
mkdir -p compat
grep -v 'DEFINE_XEN_GUEST_HANDLE(long)' public/callback.h | \
  python /home/nishaj/Xen/xen/xen/tools/compat-build-source.py >compat/callback.c.new
mv -f compat/callback.c.new compat/callback.c
/home/nishaj/gcc-linaro-4.9-2014.11-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc -E -O1 -fno-omit-frame-pointer -m64 -g -fno-strict-aliasing -std=gnu99 -Wall -Wstrict-prototypes -Wdeclaration-after-statement -Wno-unused-but-set-variable -Wno-unused-local-typedefs -I/home/nishaj/Xen/xen/xen/include -I/home/nishaj/Xen/xen/xen/include/asm-x86/mach-generic -I/home/nishaj/Xen/xen/xen/include/asm-x86/mach-default -msoft-float -fno-stack-protector -fno-exceptions -Wnested-externs -mno-red-zone -mno-sse -fpic -fno-asynchronous-unwind-tables -DGCC_HAS_VISIBILITY_ATTRIBUTE -fno-builtin -fno-common -Werror -Wredundant-decls -Wno-pointer-arith -pipe -g -D__XEN__ -nostdinc -fno-optimize-sibling-calls -DCONFIG_SHADOW_PAGING -DVERBOSE -DHAS_ACPI -DHAS_GDBSX -DHAS_PASSTHROUGH -DHAS_MEM_ACCESS -DHAS_MEM_PAGING -DHAS_MEM_SHARING -DHAS_PCI -DHAS_IOPORTS -DHAS_PDX -fno-omit-frame-pointer -DCONFIG_FRAME_POINTER -fno-optimize-sibling-calls -O1 -fno-omit-frame-pointer -m64 -g -fno-strict-aliasing -std=gnu99 -Wall -Wstrict-prototypes -Wdeclaration-after-statement -Wno-unused-but-set-variable -Wno-unused-local-typedefs -include public/xen-compat.h -m32 -o compat/callback.i compat/callback.c
aarch64-linux-gnu-gcc: error: unrecognized command line option '-m64'
aarch64-linux-gnu-gcc: error: unrecognized command line option '-msoft-float'
aarch64-linux-gnu-gcc: error: unrecognized command line option '-mno-red-zone'
aarch64-linux-gnu-gcc: error: unrecognized command line option '-mno-sse'
aarch64-linux-gnu-gcc: error: unrecognized command line option '-m32'
make[3]: *** [compat/callback.i] Error 1
rm compat/callback.c
make[3]: Leaving directory `/home/nishaj/Xen/xen/xen/include'
make[2]: *** [/home/nishaj/Xen/xen/xen/xen] Error 2
make[2]: Leaving directory `/home/nishaj/Xen/xen/xen'
make[1]: *** [install] Error 2
make[1]: Leaving directory `/home/nishaj/Xen/xen/xen'
make: *** [install-xen] Error 2
Please let me know how to resolve it ?
Thanks.
