Hi
I am trying to boot Juno linux kernel and using my boot sequence.
I am facing issue with Juno linux code where it is mapping some fixed map which i guess is due to UEFI requirement.
Is there any way I can disable it in Juno linux kernel ? or is there any way I can find out memory ranges for this fixed map and create a fake node in DT to map it so I don't run into address issues ?
I see this fixed map is getting mapped very early on in Head.S and I am wondering why it is not specified in juno DT ? How it is passed to arm-trusted-firmware ?
Thanks,
What do you mean by "using my boot sequence" ?
Linux has a well defined boot behaviour, why do you want to change it ?
Please provide more info on the issue you have ?
Which version of kernel, firmware and DTB are you using ?
Regards,
Sudeep
View all questions in Arm Development Platforms forum
