how to bypass BL3-1 arm-trusted-firmware running on Juno
I am trying to take control at EL3 level and want to run my code on Juno. I am using arm-trusted-firmware package running on Juno.
In order to achieve this I am using DS-5 debugger to breakthrough the code and setting the PC to my code but instead of executing next instruction it is jumping back to some 0x400_F000 address.
I am not sure how I can achieve this ? What i simply want is to take control at EL3 level and execute my code. I believe it is possible at BL3-1 level, is it correct ?
I found example for bare-metal applications but the control transfer is happening at EL1-NS mode whereas I need EL3 level control.
Thanks,
