Hello, all
i have one question.
i want to debugging EL level debugging on Juno Board using DS-5 in step by step.
but, i don't know how can i reset Juno Board in DS-5
I inputed "reset incommand window. but the result is as below.
ERROR(TAD43-DTS33-NAL84):
! Failed to reset device Cortex-A53_0
! Failed to read register 193 on device ETM_0_2
! Core has powered down
Is there script of Juno board for DS-5 to reset or debugging?
Resetting the Juno through DS-5 is not currently supported. This is because modern SoCs such as the Juno include a System Control Processor (SCP) that is responsible for power & thermal management. The Juno's SCP is a Cortex-M3, and the ARM Trusted Firmware Secure Monitor (running on the A-class processors) communicates with it using specific interfaces. As such, resetting a core is no longer as simple as asserting the nSRST signal through a debugger.
Regards, Ash.
View all questions in Arm Development Platforms forum
