ADRP command loading incorrect address.
Hi Arm experts,
I have a load command to load a structure in assembly code as below:
adrp x4,ASM_NAME(forkx)
This load instruction is not giving the proper address of the structure that i have intended: took the gdb trace at this point and following is the details:
1. We can see the register content at the time of load and x4 have 0x55783dd000
(gdb) info registers
x0             0x30a0   12448
x1             0x0      0
x2             0x7fdf1bf6b0     549203998384
x3             0x55ad57f898     367980443800
x4             0x55783dd000     367089537024
x5             0x0      0
x6             0x1      1
2. If i see the forkx address it is:
(gdb) print &forkx
$13 = (sprocess * __be *) 0x55783dd5c0 <__be_forkx>
My intention is to load the address 0x55783dd5c0 but it is loading 0x55783dd000. this is causing the issue in the subsequent commands as invalid address is gettig accessed.
Is this is a known behaviour with adrp? do i need to handle this with any other way? Please help me in this. Thanks.
