I have a problem,i wrote this program but it dosen't work.
It doesn't read its rx pin.
Can you help me pls ???
CODS:
PUBLIC MAINTASK PUBLIC __vector_table SECTION .text:CODE:REORDER(10) ;; Keep vector table even if it's not referenced REQUIRE __vector_table THUMBBIT0 EQU 1 << 0BIT1 EQU 1 << 1BIT2 EQU 1 << 2BIT3 EQU 1 << 3BIT4 EQU 1 << 4BIT5 EQU 1 << 5BIT6 EQU 1 << 6BIT7 EQU 1 << 7BIT8 EQU 1 << 8BIT9 EQU 1 << 9BIT10 EQU 1 << 10BIT11 EQU 1 << 11BIT12 EQU 1 << 12BIT13 EQU 1 << 13BIT14 EQU 1 << 14BIT15 EQU 1 << 15BIT16 EQU 1 << 16BIT17 EQU 1 << 17BIT18 EQU 1 << 18BIT19 EQU 1 << 19BIT20 EQU 1 << 20BIT21 EQU 1 << 21BIT22 EQU 1 << 22BIT23 EQU 1 << 23BIT24 EQU 1 << 24BIT25 EQU 1 << 25BIT26 EQU 1 << 26BIT27 EQU 1 << 27BIT28 EQU 1 << 28BIT29 EQU 1 << 29BIT30 EQU 1 << 30BIT31 EQU 1 << 31
RCC_BASE EQU 0x40023800RCC_AHB1ENR EQU RCC_BASE + 0x30RCC_APB1ENR EQU RCC_BASE + 0x40RCC_CFGR EQU RCC_BASE + 0x08
GPIOD_BASE EQU 0x40020C00GPIOD_MODER EQU GPIOD_BASE + 0x00GPIOD_ODR EQU GPIOD_BASE + 0x14GPIOD_IDR EQU GPIOD_BASE + 0x10GPIOD_BSRR EQU GPIOD_BASE + 0x18GPIOD_AFRH EQU GPIOD_BASE + 0x24
USART_SR EQU GPIOD_BASE + 0x00USART_DR EQU GPIOD_BASE + 0x04USART_BRR EQU GPIOD_BASE + 0x08USART_CR1 EQU GPIOD_BASE + 0x0C
MAINTASK LDR R0, =RCC_AHB1ENR LDR R1, [R0] ORR R1,R1,#BIT3 STR R1, [R0]
LDR R0, =RCC_APB1ENR LDR R1,[R0] ORR R1,R1,#BIT18 str R1, [R0]
LDR R0, =GPIOD_MODER LDR R1, =(BIT0|BIT2|BIT4|BIT6|BIT8|BIT10|BIT17|BIT19) STR R1, [R0]
LDR R0, =USART_CR1 LDR R1, =(BIT13|BIT2|BIT3|BIT5) STR R1, [R0]
LDR R0, =USART_BRR LDR R1, =0x341 ; BRAUD RATE 9600 STR R1, [R0]
DATASTOCONTROL LDR R2, =0x31 ;1 signal LDR R3, =0x32 ;2 signal LDR R4, =0x33 ;3 signal LDR R5, =0x34 ;4 signal
CONTROLREAD
LDR R0, =USART_SR LDR R1, [R0] MOVS R0, #BIT5 TST R0, R1 BEQ CONTROLREAD
LDR R0, =USART_DR ; USART_DR(gelen veri) degerini R0'a yükle LDR R1, [R0] ; USART_DR registerini R1'ye kopyala
MOVE
CMP R1, R2 BEQ FORWARD CMP R1, R3 BEQ BACK CMP R1, R4 BEQ RIGHT CMP R1, R5 BEQ LEFT BL CONTROLREAD
FORWARD MOV R0,#0 MOV R1,#0 LDR R0,=GPIOD_ODR MOV R1,#(BIT0|BIT2|BIT8|BIT10) STR R1,[R0] BL CONTROLREAD
BACK MOV R0,#0 MOV R1,#0 LDR R0,=GPIOD_ODR MOV R1,#(BIT4|BIT6|BIT8|BIT10) STR R1,[R0] BL CONTROLREAD
RIGHT MOV R0,#0 MOV R1,#0 LDR R0,=GPIOD_ODR MOV R1,#(BIT0|BIT6|BIT8|BIT10) STR R1,[R0] BL CONTROLREAD
LEFT MOV R0,#0 MOV R1,#0 LDR R0,=GPIOD_ODR MOV R1,#(BIT2|BIT4|BIT8|BIT10) STR R1,[R0] BL CONTROLREAD
;; Forward declaration of sections.
SECTION CSTACK:DATA:NOROOT(10) SECTION .intvec:CODE:NOROOT(10) DATA
__vector_table DCD sfe(CSTACK) DCD MAINTASK
DCD NMI_Handler DCD HardFault_Handler DCD MemManage_Handler DCD BusFault_Handler DCD UsageFault_Handler DCD 0 DCD 0 DCD 0 DCD 0 DCD SVC_Handler DCD DebugMon_Handler DCD 0 DCD PendSV_Handler DCD SysTick_Handler
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Default interrupt handlers.;;
PUBWEAK NMI_Handler PUBWEAK HardFault_Handler PUBWEAK MemManage_Handler PUBWEAK BusFault_Handler PUBWEAK UsageFault_Handler PUBWEAK SVC_Handler PUBWEAK DebugMon_Handler PUBWEAK PendSV_Handler PUBWEAK SysTick_Handler
SECTION .text:CODE:REORDER:NOROOT(10) THUMB
NMI_HandlerHardFault_HandlerMemManage_HandlerBusFault_HandlerUsageFault_HandlerSVC_HandlerDebugMon_HandlerPendSV_HandlerSysTick_HandlerDefault_Handler__default_handler CALL_GRAPH_ROOT __default_handler, "interrupt" NOCALL __default_handler B __default_handler BL MAINTASK END
So what debugging have you done to find the problem?
Have you tried working examples before leaping into swathes of unformatted, uncommented assembler?
Have you done basics like blinking LEDs?
Can you transmit?
Note that the USART has nothing to do with ARM - it is ST's proprietary IP - so you'd probably be better asking on the ST forum
community.arm.com/.../158950
View all questions in Arm Development Platforms forum
