I followed the instructions at https://git.linaro.org/landing-teams/working/arm/arm-reference-platforms.git/about/docs/sgm775/user-guide.rst
In addition to the two toolchains listed in that page I had to download gcc-arm-none-eabi-5_4-2016q3-20160926-linux.tar.bz2 after I got an error during building. After downloading it the build completed successfully.
When I tried running it I got the following output
Continue with <model_type> as sgm775 !!! Continue with <display> as dp !!! Continue with <boot_loader_type> as uboot !!! Continue with <BL1_IMAGE> as tf-bl1.bin !!! Continue with <FIP_IMAGE> as fip-uboot.bin !!! Continue with <network_enabled> as false !!! Continue with <emulator_run> as false !!! terminal_s0: Listening for serial connection on port 5000terminal_s1: Listening for serial connection on port 5001terminal_0: Listening for serial connection on port 5002terminal_1: Listening for serial connection on port 5003TracePluginInstancesManager::AddInterface(): interface 'SystemTraceInterface1' not found (in component mtiRegistry)Error: REMOTE_CONNECTION.CADIServer: error: cannot GetTargetInfosRegisterSimulation() call of plugin instance "REMOTE_CONNECTION.CADIServer" returned error CADI_STATUS_GeneralError.Error in plugin detected, aborting.SimulationEngine::simExecPort_stopAndFatalError(Failed to register all plugins);Error: General error:Kits3_SGM_775.css.gpu.gpu : GRM licence checkout failed!Fatal Error: Call of CADISimulationFactory::Instantiate(..) did not return a CADISimulation.Simulation is terminating. Reason: Simulation requested shutdown
Can someone please tell me what additional steps I need to take to make it run ?
View all questions in Arm Development Platforms forum
