How to config the fvp model to enable pac bti mte sel2 in fvp
I'm using the lastest fvp version Base_RevC_AEMv8A_pkg
And I have read the guide in fast_models_rm_100964_1180_00_en.pdf
And see the follow params:
PAC:
has_generic_authentication
has_pointer_authentication
subcluster0.has_enhanced_pac
BTI:has_branch_target_exception
SEL2:
has_secure_el2
MTE:
memory_tagging_support_level
But what's the actual param to enable it?
Is it this? clusterx.xxx=1
cluster0.has_secure_el2=1
cluster1.has_secure_el2=1
Is the follow configure right?
diff --git a/fvp/run_model.sh b/fvp/run_model.shindex 787d769..413693a 100644--- a/fvp/run_model.sh+++ b/fvp/run_model.sh@@ -110,7 +110,16 @@ else " fi cores="-C cluster0.NUM_CORES=$CLUSTER0_NUM_CORES \- -C cluster1.NUM_CORES=$CLUSTER1_NUM_CORES"+ -C cluster1.NUM_CORES=$CLUSTER1_NUM_CORES \+ -C cluster0.has_pointer_authentication=2 \+ -C cluster1.has_pointer_authentication=2 \+ -C cluster0.has_secure_el2=2 \+ -C cluster1.has_secure_el2=2 \+ -C cluster0.has_branch_target_exception=2 \+ -C cluster1.has_branch_target_exception=2 \+ -C cluster0.memory_tagging_support_level=2 \+ -C cluster1.memory_tagging_support_level=2+ "
View all questions in Arm Development Platforms forum
