Hello ADPF,
Can I run ARM Trusted Firmware on DragonBoard-410c ?
If yes, git link to the version that works on DB410c would be very helpful.
If no,
Any inputs on the above would be appreciated.
Thanks in advance !
The cores need to have TrustZone _and_ the secure mode must be accessible by the user. Some SoC use the secure mode for vendor specific stuff (for example TI).
Qualcomm DB410C uses Cortex-A53 CPUs so that Trustzone is supported. Arm Trusted Firmware can be supported accordingly.
But you have to integrate Arm Trusted Firmware to the bsp by yourself.
Please see technical reference URLs:
- https://www.96boards.org/documentation/consumer/dragonboard/dragonboard410c/hardware-docs/
- https://developer.qualcomm.com/hardware/dragonboard-410c/software
View all questions in Arm Development Platforms forum
