Hello ,
I am learning LPC2138 MCU interfacing as input-output function. May you please suggest the pull up resistor value at GPIO pin ,
Please suggest.
Thanks & Regards
AS I found in datasheet some pins (P1.16 TO P1.31) are internal pull with 68 kohm to 300kohm. And for some (P0.1 TO P0.31) external pull up is recommended. I want to know external recommended Pull up resistor value. If some one know. please suggest
note that this has nothing to do with ARM - you need to ask NXP!
https://www.nxp.com/support/support:SUPPORTHOME
View all questions in Arm Development Platforms forum
