DS5 Linux Debugging
I have a licensed version of DS5. I am currently working on debugging a linux application on the De1-SoC board (Cortex A9). Although I am following the tutorial video (https://www.youtube.com/watch?v=ZcGQEjkYWOc ) but still when I press the debug button in the debug configuration window after filling all the required information: It says,
" Unable to connect to Linux.
Reason:
Falied target configuration:
gdbserver excited unexpectedly, see the App Console for further information"
In the app console window; following appears;
Preparing the debug session
# cd "/home/root"
# export LD_LIBRARY_PATH=".:$LD_LIBRARY_PATH"
# gdbserver :5001 "./Linux_test_program"
gdbserver: command not found
It should be mentioned that I have an active remote connection via ssh to the board. The board has a running linux image with gdb server installed. Does anybody know where is the problem?
