DS-5 5.29.0 on Windows 10 1803
Hi
I'm in the process of trying to migrate DS-5 to a new laptop as I have been issued a new machine in order to support Windows 10 which is now a company requirement.
We have a perpetual node locked license for DS-5, but its gone out of support as of July last year.  The last version I have access to is 5.29.0.
Installing this version on the new machine is fine, but on starting it DS-5 will hang for minutes after selecting / creating the workspace with little, if no CPU usage and nothing in the Windows logs or Eclipse logs if I start it with a console and debug.
For interest I also installed DS 5.29.2 to see if that worked correctly and it appears to, so does that mean 5.29.0 is broken on Windows 10?
I don't see anything in the release note that indicate a bug was fixed for Window 10 support.
Any ideas appreciated.
Regards
Kevin
  • Hi Kevin
    Windows 10 is an officially supported platform of DS-5 5.29.0. In a (very quick) test on my Win 10 laptop I noticed no obvious issues.
    The easiest solution here would of course be to renew your support and maintenance, to be able to run 5.29.2.
    Please also note that DS-5 is no longer being developed - have you tried out the new Arm Development Studio?
  • Hi Kevin
