None of the images of Linaro starting from 14.06 is booting on my juno board
Hello all i'm trying to boot android on my juno board. i followed the procedure described here http://releases.linaro.org/latest/android/armv8-android-juno-lsk and also here Setting up Android on Juno
and none of them worked for me. each time i'm getting the same error.
[   49.344275] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/sda2 at /system options: (null) error: No such file or directory
[   49.357645] init: fs_mgr_mount_all returned an error
this means that kernel is not able to mount the /system partition.
when i checked the logs on the video posted in this page i noticed that kernel is recognizing only 1 usb port instead of 4.
i tried using different USB sticks and different linaro images starting from 14.06 till the latest and i still have the same problem.
when searching i hit this conversation on linaro irc https://irclogs.linaro.org/2014/07/18/%23linaro-android.txt but there was no solution.
you can find attached the logs of the kernel boot.
Can you please enlighten me.
thank you very much in advance for your help
juno_kernel_boot.log.zip
  • I know this in an old post, but was wondering, my Linaro machine is stuck half way through loading and I cant get to a command prompt to fix the issues...
    is there a hotkey to skip though to a "safe mode" ?
    I dont have a boot menu pop up at all, and googling didnt provide any help either
