Has anyone tried using KVM with the Juno board? It doesn't look like the bootloader starts the cores in hypervisor mode, so it's not clear to me whether the current system software will support a hypervisor at the moment, even with the appropriate kernel options selected. Are there any plans to support it?
[Sudeep] Yes you can run KVM on JUNO atleast on Cortex-A57
[Sudeep] Not sure what you mean by this, IIUC UEFI starts Linux in EL2(at-least in the release I am using)
[Sudeep] Surely it does
[Sudeep] AFAIK, most of the required options are enabled in the upstream kernel(v3.17-rc*), you can pick defconfig from there for KVM
[Sudeep] It's already supported.
If you run and get into troubles, post the log messages which will help us to guide you.
You can refer [1] but just use [2] kernel tree to build kvmtool
Regards,
Sudeep
[1] https://github.com/penberg/linux-kvm/blob/master/tools/kvm/README
[2] https://git.kernel.org/cgit/linux/kernel/git/will/kvmtool.git/log/?h=kvmtool/arm
Sorry for the late follow-up. It looks to me like KVM is trying to start up, but that perhaps the A53s aren't supported. I see in dmesg the following:
[ 0.542916] kvm [1]: Error, CPU 0 not supported!
I see from the most recent firmware release that the trusted firmware supports "nominating any CPU as the primary CPU without recompiling the firmware." Would it help to make CPU 4 (in my case, the first A57) the primary CPU? I don't see any documentation for how I would do that. Any suggestions?
Yes A53 is not yet added in the kvmtool. I should have been explicit about this in
my earlier reply. I just mentioned that I have tested on A57, sorry for that.
Instead of taking troubles to make CPU4 boot cpu, how about using taskset to
affine the task to A57. I use it in that way, something like:
$ taskset 0x30 ./lkvm run <arg_list_you_are_using_now>
In my case it appears that KVM isn't initializing at all. I'm missing /dev/kvm (which I assumed was related to the dmesg output I posted earlier). In your experiments, do you have the /dev/kvm device? I haven't tried kvmtool because I assumed that nothing would work without the /dev/kvm device.
It is not initializing because you are probably using an ancient kernel (pre 3.16), which doesn't recognize A53 as a valid CPU for virtualization. Please use a recent enough kernel.
As Sudeep mentioned above, you will also need an updated userspace (or use the taskset workaround).
Thanks,
M.
View all questions in Arm Development Platforms forum
