I've got Juno Dev board in yesterday.
Unfortunately, I think it can't recognize any usb storage.
When I plugged this usb stick in my host PC, the host PC can mount the two parttiton(boot, rootfs) perfectly.
What't the problem of the usb storage?
Here it is my firmware version:
ARM V2M-Juno Boot loader v1.0.0HBI0262 build 596
ARM V2M_Juno Firmware v1.1.7Build Date: May 27 2014
This is my kernel log. It stuck because it cant't find /dev/sda2
cmdline: console=ttyAMA0,115200 root=/dev/sda2 rootwait loglevel=8
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.15.0-rc8+ (cometzero@cometzero-ubuntu) (gcc version 4.9.1 20140505 (prerelease) (crosstool-NG linaro-1.13.1-4.9-2014.05 - Linaro GCC 4
[ 0.000000] CPU: AArch64 Processor [410fd030] revision 0
[ 0.000000] cma: CMA: reserved 32 MiB at fc800000
[ 0.000000] On node 0 totalpages: 2093056
[ 0.000000] DMA zone: 7168 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 520192 pages, LIFO batch:31
[ 0.000000] Normal zone: 21504 pages used for memmap
[ 0.000000] Normal zone: 1572864 pages, LIFO batch:31
[ 0.000000] psci: probing function IDs from device-tree
[ 0.000000] PERCPU: Embedded 11 pages/cpu @ffffffc97ff86000 s14144 r8192 d22720 u45056
[ 0.000000] pcpu-alloc: s14144 r8192 d22720 u45056 alloc=11*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2064384
[ 0.000000] Kernel command line: console=ttyAMA0,115200 root=/dev/sda2 rootwait loglevel=8
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 8200472K/8372224K available (5427K kernel code, 380K rwdata, 1980K rodata, 233K init, 538K bss, 171752K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000 (245759 MB)
[ 0.000000] vmemmap : 0xffffffbc01c00000 - 0xffffffbc23000000 ( 532 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc980000000 ( 38912 MB)
[ 0.000000] .init : 0xffffffc0007bd000 - 0xffffffc0007f7740 ( 234 kB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc0007bceb4 ( 7412 kB)
[ 0.000000] .data : 0xffffffc0007f8000 - 0xffffffc000857200 ( 381 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] Architected cp15 and mmio timer(s) running at 50.00MHz (phys/phys).
[ 0.000006] sched_clock: 56 bits at 50MHz, resolution 20ns, wraps every 2748779069440ns
[ 0.000180] Console: colour dummy device 80x25
[ 0.007604] allocated 33554432 bytes of page_cgroup
[ 0.007611] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.007626] Calibrating delay loop (skipped), value calculated using timer frequency.. 100.00 BogoMIPS (lpj=500000)
[ 0.007638] pid_max: default: 32768 minimum: 301
[ 0.007713] Security Framework initialized
[ 0.007739] Smack: Initializing.
[ 0.007799] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.007811] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.008654] Initializing cgroup subsys debug
[ 0.008669] Initializing cgroup subsys memory
[ 0.008686] Initializing cgroup subsys devices
[ 0.008694] Initializing cgroup subsys freezer
[ 0.008702] Initializing cgroup subsys blkio
[ 0.008710] Initializing cgroup subsys perf_event
[ 0.009119] /cpus/cpu@100: Missing clock-frequency property
[ 0.009137] /cpus/cpu@101: Missing clock-frequency property
[ 0.009154] /cpus/cpu@102: Missing clock-frequency property
[ 0.009173] /cpus/cpu@103: Missing clock-frequency property
[ 0.009193] /cpus/cpu@0: Missing clock-frequency property
[ 0.009215] /cpus/cpu@1: Missing clock-frequency property
[ 0.009229] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[ 0.061621] CPU1: Booted secondary processor
[ 0.081621] CPU2: Booted secondary processor
[ 0.101635] CPU3: Booted secondary processor
[ 0.136531] CPU4: Booted secondary processor
[ 0.151709] CPU5: Booted secondary processor
[ 0.151833] Brought up 6 CPUs
[ 0.151861] SMP: Total of 6 processors activated.
[ 0.152521] devtmpfs: initialized
[ 0.165934] atomic64 test passed
[ 0.166359] regulator-dummy: no parameters
[ 0.170360] NET: Registered protocol family 16
[ 0.170919] cpuidle: using governor ladder
[ 0.170930] cpuidle: using governor menu
[ 0.171015] vdso: 2 pages (1 code, 1 data) at base ffffffc0007fd000
[ 0.171048] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.172638] software IO TLB [mem 0xfec00000-0xff000000] (4MB) mapped at [ffffffc07ec00000-ffffffc07effffff]
[ 0.172647] Serial: AMBA PL011 UART driver
[ 0.175772] of_amba_device_create(): amba_device_add() failed (-19) for /dma@0x7ff00000
[ 0.176074] 7ff80000.uart: ttyAMA0 at MMIO 0x7ff80000 (irq = 115, base_baud = 0) is a PL011 rev3
[ 0.635834] console [ttyAMA0] enabled
[ 0.660210] 3V3: 3300 mV
[ 0.663312] SCSI subsystem initialized
[ 0.667202] libata version 3.00 loaded.
[ 0.671319] usbcore: registered new interface driver usbfs
[ 0.676842] usbcore: registered new interface driver hub
[ 0.682213] usbcore: registered new device driver usb
[ 0.689885] NetLabel: Initializing
[ 0.693253] NetLabel: domain hash size = 128
[ 0.697576] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.702538] NetLabel: unlabeled traffic allowed by default
[ 0.708173] Switched to clocksource arch_sys_counter
[ 0.728071] NET: Registered protocol family 2
[ 0.732830] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.740333] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.747467] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.754020] TCP: reno registered
[ 0.757220] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.763343] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.770078] NET: Registered protocol family 1
[ 0.774689] RPC: Registered named UNIX socket transport module.
[ 0.780562] RPC: Registered udp transport module.
[ 0.785217] RPC: Registered tcp transport module.
[ 0.789884] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.796703] kvm [1]: Error, CPU 0 not supported!
[ 0.802897] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.809896] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.835203] NFS: Registering the id_resolver key type
[ 0.840263] Key type id_resolver registered
[ 0.844405] Key type id_legacy registered
[ 0.848396] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.855275] fuse init (API version 7.23)
[ 0.860064] msgmni has been set to 16080
[ 0.865567] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.872909] io scheduler noop registered
[ 0.877048] io scheduler cfq registered (default)
[ 0.882350] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.890533] [drm] Initialized drm 1.1.0 20060810
[ 0.905614] brd: module loaded
[ 0.913852] loop: module loaded
[ 0.917794] zram: Created 1 device(s) ...
[ 0.923820] libphy: smsc911x-mdio: probed
[ 0.998320] smsc911x 18000000.ethernet eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=18000000.etherne:01, irq=-1)
[ 1.009728] smsc911x 18000000.ethernet eth0: MAC Address: 00:02:f7:00:58:81
[ 1.016664] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.023158] ehci-h20ahb: H20AHB-EHCI Host Controller driver
[ 1.028810] ehci-h20ahb 7ffc0000.ehci: EHCI Host Controller
[ 1.034349] ehci-h20ahb 7ffc0000.ehci: new USB bus registered, assigned bus number 1
[ 1.043537] ehci-h20ahb 7ffc0000.ehci: irq 149, io mem 0x7ffc0000
[ 1.049588] ehci-h20ahb 7ffc0000.ehci: enabled 64bit DMA
[ 1.068185] ehci-h20ahb 7ffc0000.ehci: USB 2.0 started, EHCI 1.00
[ 1.075344] hub 1-0:1.0: USB hub found
[ 1.079100] hub 1-0:1.0: 1 port detected
[ 1.083494] ULPI transceiver vendor/product ID 0x0424/0x0009
[ 1.089110] Found SMSC USB334x ULPI transceiver.
[ 1.093682] ULPI integrity check: passed.
[ 1.097815] usbcore: registered new interface driver usb-storage
[ 1.104054] mousedev: PS/2 mouse device common for all mice
[ 1.110293] rtc-pl031 1c170000.rtc: rtc core: registered pl031 as rtc0
[ 1.116802] i2c /dev entries driver
[ 1.121356] usbcore: registered new interface driver usbhid
[ 1.126872] usbhid: USB HID core driver
[ 1.135851] ion_chunk_heap_create: base 4227858432 size 4194304 align 16384
[ 1.148263] ashmem: initialized
[ 1.151640] logger: created 256K log 'log_main'
[ 1.162270] logger: created 256K log 'log_events'
[ 1.167173] logger: created 256K log 'log_radio'
[ 1.172028] logger: created 256K log 'log_system'
[ 1.177154] Channel(mhu_ctlr:cpu_to_scp_low) not found!
[ 1.182353] scpi_clocks clocks.3: failed to register clock 'vbig'
[ 1.188412] platform clocks.3: Driver scpi_clocks requests probe deferral
[ 1.195318] mhu_ctlr_drv 2b1f0000.mhu: registered mailbox controller mhu_ctlr
[ 1.202690] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.208234] arp_tables: (C) 2002 David S. Miller
[ 1.212874] TCP: cubic registered
[ 1.217165] NET: Registered protocol family 10
[ 1.222685] mip6: Mobile IPv6
[ 1.225651] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.231248] sit: IPv6 over IPv4 tunneling driver
[ 1.236556] NET: Registered protocol family 17
[ 1.241055] Key type dns_resolver registered
[ 1.318308] rtc-pl031 1c170000.rtc: setting system clock to 2000-02-21 21:37:45 UTC (951169065)
�[ 1.328357] Waiting for root device /dev/sda2...
Can you confirm that the USB drive is inserted into the rear panel of the Juno Motherboard?
Yes. I tried to insert my stick all usb port.
I also tried to boot using another usb.
Unfortunately, the result was same
Can you confirm you followed the steps listed in the 'Deploying a root filesystem' section on the 'Juno Software Guide' page?
Could you see "USB hub found" message in your log?
When I tried with my juno board, I could see that USB hub is found in the logs. Please see below my logs.
[0.958116] NET: Registered protocol family 17
[0.962595] Key type dns_resolver registered
[1.043505] rtc-pl031 1c170000.rtc: setting system clock to 2014-07-25 12:32:32 UTC (1406291552)
[1.053424] Waiting for root device /dev/sda1...
[1.163403] usb 1-1: new high-speed USB device number 2 using ehci-h20ahb
[1.314603] hub 1-1:1.0: USB hub found
[1.318490] hub 1-1:1.0: 4 ports detected
I attached my boot log using NOR flash and no attaching any USB.
I also found the USB hub like yours. When I tried attaching the USB which includes OpenEmbedded, however, the board could'nt find the USB hub nodes.
[ 0.000000] Linux version 3.15.0-rc8+ (dliviu@e106497-lin) (gcc version 4.8.3 20131111 (prerelease) (crosstool-NG linaro-1.13.1-4.8-4
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] cma: CMA: reserved 16 MiB at fd800000
[ 0.000000] PERCPU: Embedded 11 pages/cpu @ffffffc97ff85000 s14080 r8192 d22784 u45056
[ 0.000000] pcpu-alloc: s14080 r8192 d22784 u45056 alloc=11*4096
[ 0.000000] Kernel command line: console=ttyAMA0,115200 earlyprintk=pl011,0x7ff80000 root=/dev/sda1 rootwait verbose debug
[ 0.000000] Memory: 8217476K/8372224K available (5170K kernel code, 364K rwdata, 1888K rodata, 217K init, 291K bss, 154748K reserved)
[ 0.000000] .init : 0xffffffc000766000 - 0xffffffc00079c700 ( 218 kB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc000765b04 ( 7063 kB)
[ 0.000000] .data : 0xffffffc00079d000 - 0xffffffc0007f8220 ( 365 kB)
[ 0.008322] Console: colour dummy device 80x25
[ 0.020251] allocated 33554432 bytes of page_cgroup
[ 0.025192] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.033239] Calibrating delay loop (skipped), value calculated using timer frequency.. 100.00 BogoMIPS (lpj=500000)
[ 0.043837] pid_max: default: 32768 minimum: 301
[ 0.048632] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.055618] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.063758] Initializing cgroup subsys debug
[ 0.068108] Initializing cgroup subsys memory
[ 0.072530] Initializing cgroup subsys devices
[ 0.077032] Initializing cgroup subsys freezer
[ 0.081546] Initializing cgroup subsys blkio
[ 0.085872] Initializing cgroup subsys perf_event
[ 0.091016] /cpus/cpu@100: Missing clock-frequency property
[ 0.096690] /cpus/cpu@101: Missing clock-frequency property
[ 0.102348] /cpus/cpu@102: Missing clock-frequency property
[ 0.108018] /cpus/cpu@103: Missing clock-frequency property
[ 0.113677] /cpus/cpu@0: Missing clock-frequency property
[ 0.119172] /cpus/cpu@1: Missing clock-frequency property
[ 0.124650] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[ 0.194541] CPU1: Booted secondary processor
[ 0.214541] CPU2: Booted secondary processor
[ 0.244990] CPU3: Booted secondary processor
[ 0.267335] CPU4: Booted secondary processor
[ 0.285054] CPU5: Booted secondary processor
[ 0.285177] Brought up 6 CPUs
[ 0.309803] SMP: Total of 6 processors activated.
[ 0.315212] devtmpfs: initialized
[ 0.332076] atomic64 test passed
[ 0.335748] regulator-dummy: no parameters
[ 0.343477] NET: Registered protocol family 16
[ 0.348522] cpuidle: using governor ladder
[ 0.352697] cpuidle: using governor menu
[ 0.356776] vdso: 2 pages (1 code, 1 data) at base ffffffc0007a5000
[ 0.363181] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.371645] software IO TLB [mem 0xfec00000-0xff000000] (4MB) mapped at [ffffffc07ec00000-ffffffc07effffff]
[ 0.381535] Serial: AMBA PL011 UART driver
[ 0.388839] of_amba_device_create(): amba_device_add() failed (-19) for /dma@0x7ff00000
[ 0.397281] 7ff80000.uart: ttyAMA0 at MMIO 0x7ff80000 (irq = 115, base_baud = 0) is a PL011 rev3
[ 0.406204] console [ttyAMA0] enabled
[ 0.413501] bootconsole [earlycon0] disabled
[ 0.436762] 3V3: 3300 mV
[ 0.439875] SCSI subsystem initialized
[ 0.443775] libata version 3.00 loaded.
[ 0.447879] usbcore: registered new interface driver usbfs
[ 0.453379] usbcore: registered new interface driver hub
[ 0.458762] usbcore: registered new device driver usb
[ 0.466375] Switched to clocksource arch_sys_counter
[ 0.484813] NET: Registered protocol family 2
[ 0.489630] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.497667] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.506012] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.512564] TCP: reno registered
[ 0.515767] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.522077] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.529010] NET: Registered protocol family 1
[ 0.533655] RPC: Registered named UNIX socket transport module.
[ 0.539531] RPC: Registered udp transport module.
[ 0.544185] RPC: Registered tcp transport module.
[ 0.548850] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.555755] kvm [1]: Error, CPU 0 not supported!
[ 0.561747] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.568681] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.591203] NFS: Registering the id_resolver key type
[ 0.596238] Key type id_resolver registered
[ 0.600399] Key type id_legacy registered
[ 0.604378] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.611249] fuse init (API version 7.23)
[ 0.615926] msgmni has been set to 16081
[ 0.620997] io scheduler noop registered
[ 0.625104] io scheduler cfq registered (default)
[ 0.630361] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.638349] [drm] Initialized drm 1.1.0 20060810
[ 0.651839] brd: module loaded
[ 0.659373] loop: module loaded
[ 0.664412] libphy: smsc911x-mdio: probed
[ 0.746512] smsc911x 18000000.ethernet eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=18000000.etherne:01, irq=-1)
[ 0.757903] smsc911x 18000000.ethernet eth0: MAC Address: 00:02:f7:00:58:81
[ 0.764834] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.771322] ehci-h20ahb: H20AHB-EHCI Host Controller driver
[ 0.776969] ehci-h20ahb 7ffc0000.ehci: EHCI Host Controller
[ 0.782508] ehci-h20ahb 7ffc0000.ehci: new USB bus registered, assigned bus number 1
[ 0.792393] ehci-h20ahb 7ffc0000.ehci: irq 149, io mem 0x7ffc0000
[ 0.798448] ehci-h20ahb 7ffc0000.ehci: enabled 64bit DMA
[ 0.816392] ehci-h20ahb 7ffc0000.ehci: USB 2.0 started, EHCI 1.00
[ 0.823536] hub 1-0:1.0: USB hub found
[ 0.827306] hub 1-0:1.0: 1 port detected
[ 0.831697] ULPI transceiver vendor/product ID 0x0424/0x0009
[ 0.837314] Found SMSC USB334x ULPI transceiver.
[ 0.841886] ULPI integrity check: passed.
[ 0.846031] usbcore: registered new interface driver usb-storage
[ 0.852236] mousedev: PS/2 mouse device common for all mice
[ 0.858510] rtc-pl031 1c170000.rtc: rtc core: registered pl031 as rtc0
[ 0.865023] i2c /dev entries driver
[ 0.869512] usbcore: registered new interface driver usbhid
[ 0.875029] usbhid: USB HID core driver
[ 0.879655] ashmem: initialized
[ 0.883005] logger: created 256K log 'log_main'
[ 0.887735] logger: created 256K log 'log_events'
[ 0.892645] logger: created 256K log 'log_radio'
[ 0.897486] logger: created 256K log 'log_system'
[ 0.902579] Channel(mhu_ctlr:cpu_to_scp_low) not found!
[ 0.907769] scpi_clocks clocks.3: failed to register clock 'vbig'
[ 0.913817] platform clocks.3: Driver scpi_clocks requests probe deferral
[ 0.920733] mhu_ctlr_drv 2b1f0000.mhu: registered mailbox controller mhu_ctlr
[ 0.928085] TCP: cubic registered
[ 0.932328] NET: Registered protocol family 10
[ 0.937779] mip6: Mobile IPv6
[ 0.940718] sit: IPv6 over IPv4 tunneling driver
[ 0.946025] NET: Registered protocol family 17
[ 0.950530] Key type dns_resolver registered
[ 1.026529] rtc-pl031 1c170000.rtc: setting system clock to 2000-02-24 17:44:09 UTC (951414249)
�[ 1.036330] Waiting for root device /dev/sda1...
[ 1.146429] usb 1-1: new high-speed USB device number 2 using ehci-h20ahb
[ 1.297698] hub 1-1:1.0: USB hub found
[ 1.301584] hub 1-1:1.0: 4 ports detected
[ 1.413880] usb 1-1: USB disconnect, device number 2
Hi Luke,
Yes. I followed each steps of the guide page.
I also tried the booting using linaro's page.
http://releases.linaro.org/14.06/openembedded/juno-lsk/
View all questions in Arm Development Platforms forum
