I was trying to upgrade to the latest firmwares, but I met a problem saying "Failed to operation.." during writing images.
In an attempt to fix the problem, I erased images stored in Motherboard eeprom any how. After that, booting is failed. (Please see the below log)
Is there any way to fix the problem?
====== booting log ======
ARM V2M-Juno Boot loader v1.0.0
HBI0262 build 596
ERROR: Invalid EEPROM contents
ARM V2M_Juno Firmware v1.1.7
Build Date: May 27 2014
Time : 17:51:49
Date : 11:02:2015
ERROR: Invalid EEPROM contents for Mother Board
Cmd> reboot
Powering up system...
Failed to read configuration file...
Powering down...
Switching off ATX PSU.
Board powered down, use REBOOT to restart.
Cmd>
Thanks in advance,
Jin Choi
Hi Jin,
Can you please type the following commands:
Cmd> EEPROM
CMd> readcf 0
What is the output?
Hi Luke,
Here is the output;
Cmd> eeprom
EEPROM> readcf 0
0000 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
Could you please e-mail support@arm.com directly regarding this issue?
Thanks,Luke
View all questions in Arm Development Platforms forum
