How do you change Linux command line on Juno?
Just like the title says, where do you change the command line Juno uses to boot linux?
Thanks,
Ali
  • I believe you are referring to the kernel command line arguments? is so, you can use UEFI to change these options. During the boot sequence, interrupt the automatic kernel boot UEFI performs by pressing a key. Navigate to '[3] Boot Manager' then to '[2] Update Boot Device Entry'. One of the entries is "Arguments to pass to the binary: ". For example:
    The default boot selection will start in  10 seconds
    [1] Linux from NOR Flash
    [2] Shell
    [3] Boot Manager
    Start: 3
    [1] Add Boot Device Entry
    [3] Remove Boot Device Entry
    [4] Update FDT path
    [5] Return to main menu
    Choice: 2
    Update entry: 1
    File path of the EFI Application or the kernel: Image
    Has FDT support? [y/n] y
    Add an initrd: [y/n] y
    File path of the initrd:
    Arguments to pass to the binary: console=ttyAMA0,115200 earlyprintk=pl011,0x7ff80000 root=/dev/sda1 rootwait verbose debug
    [2] Shell
    [3] Boot Manager
    Start: 3
    [4] Update FDT path
    Choice: 2
    Update entry: 1
