I am developing the model of a block for a virtual platform using Lisa+.
I know how to trigger a behaviour through read and write accesses on the PVBus. However I don't know how to do that for a slave port <signal>.
Can you please explain me how to do that? I haven't been able to find anything in the documentation.
I would really appreciate if you provide me with some simple example code.
Thank you in advance.
Best regards,
R.
Hi Rob,
thank you for the explanation. Yes, I'm using Fast Models.
I've been able to implement it now. The idea of having a setValue behaviour for implementing the sensitivity of a slave port was a bit misleading for me, but now I have understood.
Are you using Fast Models to do this? If so, take a look at the signalogger component. This has examples of how to do this on both slave and master ports. In summary signal_master_port.setValue(sg::Signal::Set); will set the signal and signal_master_port.setValue(sg::Signal::Clear); will clear it.
View all questions in Arm Development Platforms forum
