Will the current ARM Beetle board be upgradeable to BT5 via firmware update, or is a hardware revision required?
I can confirm that Bluetooth 5 support would require a different hardware than the one that has been implemented in Beetle. The ARM Cordio radio block within Beetle has been optimized for Bluetooth 4.2 to reduce the power consumption and increase the efficiency. This optimization is not possible with a software-defined, flexible radio, that would support new protocols by SW update.
View all questions in Arm Development Platforms forum
