I am trying to compile PMU Cycle Counter as per the code available in this blog PMU Enable on a RPI3 B+ using Suse 64 bits Aarch 64 4.12.14-lp150.12.28-default.
I have the Assembly error on each MRC or MCR instructions. In the ARM i have the feeling that instructions and implementations are different
/tmp/ccQtUeOs.s: Assembler messages:/tmp/ccQtUeOs.s:41: Error: unknown mnemonic `mrc' -- `mrc p15,0,x0,c9,c14,0'/tmp/ccQtUeOs.s:55: Error: unknown mnemonic `mcr' -- `mcr p15,0,x0,c9,c14,0'/tmp/ccQtUeOs.s:100: Error: unknown mnemonic `mrc' -- `mrc p15,0,x19,c9,c14,0'/tmp/ccQtUeOs.s:120: Error: unknown mnemonic `mcr' -- `mcr p15,0,x19,c9,c14,0'
To read the CCNTR, THE Aarch32 was asm volatile("MRC p15, 0, %0, c9, c13, 0 \t\n" : "=r"(cycle_count)); and i need to translate too into
I cannot find the equivalence from Aarch32 to Aarch64 to read PMCCNTR_EL0 and so to enable the module kernel and read the counter. Did you find someone who fix it ? Unfortunatly I found nothing ready to go for dummies (like i am on this topic) !
Thanks regards
Architecture: aarch64Byte Order: Little EndianCPU(s): 4On-line CPU(s) list: 0-3Thread(s) per core: 1Core(s) per socket: 4Socket(s): 1NUMA node(s): 1Model: 4BogoMIPS: 38.40NUMA node0 CPU(s): 0-3Flags: fp asimd evtstrm crc32 cpuid
Hi, I solved it using this thread ARM-64 PMU. it's working like a charm. Topic closed.
How ever the outcome of the method is it's linux header , kernel release, dependant to set the user PMU access.
Regards
View all questions in Arm Development Platforms forum
