I am booting the juno board with coresight enabled in config file and the nodes in DT file are also correctly kept then also the coresight components are not getting registered though the board is booting
Please can you make sure you follow these instructions to download and install the latest board firmware on your Juno; it's possible you're using an old system control processor (SCP) firmware blob that doesn't power on the DAPs:
https://community.arm.com/dev-platforms/w/docs/304/arm-reference-platforms-deliverables
You can also try manually waking the DAPs, as seen in the CoreSight access library demo's juno_wake_dap.cst csat script shipped with Arm Development Studio:
\examples\CoreSight_Access_Library.zip\CoreSight_access\demos\juno_demo_setup\juno_wake_dap.cst
# Wake DAPS on a Juno system - allow CSAL to access CS debug hardware echo Powering Juno DAPs.
# set the scan chain. chain dev=ARMCS-DP,ARMCS-DP
# connect to first - will force power up dvo 0
# check DP register for power ACK bits drr dp.csw
dvc
# connect to second - will force power up dvo 1
echo Done
Can you provide details on which kernel and dtbs are you using ?
I checked the latest 18.10 release but the DTBs are empty there, so I need to check the DTB you are running ?
View all questions in Arm Development Platforms forum
