Simple question, but very hard to find answer, maybe somebody here knows:
I want to create a simple macro like I can in C:
#define ALIGN_UP(addr, align) (((addr) + (align) - 1) & ~((align) - 1))
I've tried:
MACRO ALIGN_UP $addr,$align ((($addr) + ($align) - 1) & ~(($align) - 1)) MEND
but this doesn't work:
MYVAR EQU ALIGN_UP(768, 1024)
I get "error A2173: syntax error in expression".
I've also tried:
MACRO ALIGN_UP $var,$addr,$align $var EQU ((($addr) + ($align) - 1) & ~(($align) - 1)) MEND
But this also doesn't work:
ALIGN_UP(MYVAR, 768, 1024)
I get "error A2007: wrong operand type for '-'"
In the examples above I use numbers, but of course what I want to accomplish is like this:
IMAGE_BOOT_BOOTIMAGE_START_OFFSET EQU ALIGN_UP(IMAGE_BOOT_BOOTIMAGE_CSF_OFFSET+IMAGE_BOOT_BOOTIMAGE_CSF_SIZE, 1024)
This of course works just fine:
IMAGE_BOOT_BOOTIMAGE_START_OFFSET EQU (((IMAGE_BOOT_BOOTIMAGE_CSF_OFFSET+IMAGE_BOOT_BOOTIMAGE_CSF_SIZE) + (1024 - 1)) & ~(1024 - 1))
But it's a maintenance nightmare.
Surely using macros like this must be possible in ARM assembly?
It is likely that the asm preprocessor does not work recursively or in more than one stages (that is typical IMHO). So, using a preprocessor directive to generate another directive or its part might not be possible.
cpreproc and cpreproc_opts may help; that involves including a C header file, containing the definition, into the asm file.
-amol
View all questions in Arm Development Platforms forum
