ARM assembler macro question
Simple question, but very hard to find answer, maybe somebody here knows:
I want to create a simple macro like I can in C:
#define ALIGN_UP(addr, align)   (((addr) + (align) - 1) & ~((align) - 1))
I've tried:
MACRO
ALIGN_UP $addr,$align
((($addr) + ($align) - 1) & ~(($align) - 1))
MEND
but this doesn't work:
MYVAR    EQU    ALIGN_UP(768, 1024)
I get "error A2173: syntax error in expression".
I've also tried:
MACRO
ALIGN_UP $var,$addr,$align
$var EQU ((($addr) + ($align) - 1) & ~(($align) - 1))
MEND
But this also doesn't work:
ALIGN_UP(MYVAR, 768, 1024)
I get "error A2007: wrong operand type for  '-'"
In the examples above I use numbers, but of course what I want to accomplish is like this:
IMAGE_BOOT_BOOTIMAGE_START_OFFSET   EQU    ALIGN_UP(IMAGE_BOOT_BOOTIMAGE_CSF_OFFSET+IMAGE_BOOT_BOOTIMAGE_CSF_SIZE, 1024)
This of course works just fine:
IMAGE_BOOT_BOOTIMAGE_START_OFFSET   EQU     (((IMAGE_BOOT_BOOTIMAGE_CSF_OFFSET+IMAGE_BOOT_BOOTIMAGE_CSF_SIZE) + (1024 - 1)) & ~(1024 - 1))
But it's a maintenance nightmare.
Surely using macros like this must be possible in ARM assembly?
  • Hello,
    It is likely that the asm preprocessor does not work recursively or in more than one stages (that is typical IMHO). So, using a preprocessor directive to generate another directive or its part might not be possible.
    cpreproc and cpreproc_opts may help; that involves including a C header file, containing the definition, into the asm file.
    -amol
  • Hello,
    -amol
