I've found an error in the wiki, specifically in TFTP (remote/network kernel) using U-Boot. I joined the community, thinking I could fix the problem, but still can't find any info on how to edit a specific page. Do I have to wait a certain amount of time, or is there some other hurdle I must jump?
BTW, the error is about halfway down the page:
VExpress64# set origbootcmd "$bootcmd" VExpress64# set bootcmd "dhcp: tftp ${kernel_addr} ${serverip}:Image; tftp ${fdt_addr} ${serverip}:juno/juno.dtb; booti ${kernel_addr} - ${fdt_addr}" VExpress64# saveenv
At the least that ":" after "dhcp" should be a semicolon, but also the dhcp command will by default try to boot from the network. Fixed version:
VExpress64# set origbootcmd "$bootcmd" VExpress64# set autoload no VExpress64# set bootcmd "dhcp; tftp ${kernel_addr} ${serverip}:Image; tftp ${fdt_addr} ${serverip}:juno/juno.dtb; booti ${kernel_addr} - ${fdt_addr}" VExpress64# saveenv
Hi Dan Griscom I've moved this to the Arm Development Platforms forum where you should get a faster response. Ash Wilding Michele Wilkinson may be able to help.
Many thanks,Georgia
Hi Dan Griscom,
Apologies for the confusion, the wiki pages can only be edited by Arm employees, however by joining the community you are able to participate in discussions on the forum.
Thank you for identifying and providing a fix for the issue in the TFTP tutorial -- I've updated the page to reflect this :-)
Many thanks,Ash.
View all questions in Arm Development Platforms forum
