Hello every one, I am newbie in ARM development. Currently I saw an open source project with the name TREZOR (A bitcoin wallet) and the processor they used is ARM Cortex M3 based processor. All its detail related to hardware and uploading firmware and boot loader is available on GitHub https://github.com/trezor. The problem is that I wanna make some changes in their code using GNU ARM Eclipse compiler. But their code is not in simple form as it is in Eclipse compiler, link for source code is https://github.com/trezor/trezor-mcu . Kindly see the containing folder of source code and help me in making some changes to main code in Eclipse or some other compiler. Thanks in advance
Hi Engr,
This is a forum for technical discussion and support. So if is difficult for us to make the changes directly for you.
If you change the code by yourself and meet some technical questions, you can post them here for discussion or guide.
Thanks.
View all questions in Arm Development Platforms forum
