AMD program on ARM
Hey i have question.
I have a problem with execution of program (64-bit) I'ts a bioinformatic program (http://ffas.sanfordburnham.org/ffas-cgi/cgi/download.pl?ses=&rv=&lv= [with source code]) I building a cluster of 5x orange pi one plus (http://www.orangepi.org/OrangePiOneplus/) just for education purpose and fun when I assigned PATH, given chmod permission i still get
cannot execute binary file: Exec format error
So I quess is all about architecture I start a program for AMD? How can I compile source code for ARM?
here's my cluster
Best
  • Hi,
    Yes, it sounds like this is an executable built for the wrong architecture. You can verify what architecture an executable is built for using the "file" command:  For example:
    file ./u-boot.elf
    ./u-boot.elf: ELF 64-bit LSB executable, ARM aarch64, version 1 (SYSV), statically linked, not stripped
    If you have Debian or Ubuntu running on your Pi Plus - you should be able to install a suitable toolchain package (gcc, gfortran etc)
    Normally if sources are supplied, there will also be a makefile or some build instructions - allowing you to try rebuilding natively for arm or arm64.
    Sometimes it isn't as simple as just recompiling - depends whether there are any architecture specific assumptions in the source code.
    Advice on re-building a specific example from source is probably a question best put to the provider.
    MarkN
