Issue while building the OpenEmbedded filesysytem from source (ARM Versatile Express Juno r2 Development Platform)
Similar to this thread, i'm having some hard time building the openembedded filesystem.
So far I have managed to follow this tutoriall until the "Booting the board" section. After running the board some errors appear during the execution:
Execution of the PuTTY shell (Part 1)
Execution of the PuTTY shell (Part 2)
This lead me to follow the "Addendum B: Building the OpenEmbedded filesysytem from source"
(I thought this part was optional since in this section "Initialising a workspace" it says "The script will guide you through the process of initialising your workspace, automatically downloading all relevant source files and required binaries.")
I executed this commands with no problems:
/* Create workspace */
/* WARNING: Do *not* create this as a subdirectory of the main Linaro Arm Platforms workspace created by `workspace_yy.mm' above */
$ mkdir openembedded
$ cd openembedded
$ export OE_HOME=`pwd`
$ git clone git://git.linaro.org/openembedded/jenkins-setup.git
$ cd $OE_HOME/jenkins-setup
$ git checkout release-YY.MM
$ cd $OE_HOME
$ sudo jenkins-setup/pre-build-root-install-dependencies.sh
$ jenkins-setup/init-and-build.sh
$ cd $OE_HOME/openembedded-core
$ ./oe-init-build-env
/* Add bitbake to your $PATH */
$ export PATH=$OE_HOME/openembedded-core/bitbake/bin:$PATH
But, after running this commands:
$ cd $OE_HOME/build
$ bitbake-layers show-recipes
I get the following Warnings and Errors (from the log file located in the directory /Desktop/openembedded/build/tmp-glibc/log/cooker)):
WARNING: /home/lfpm1993/Desktop/openembedded/meta-linaro/meta-ilp32/recipes-overlayed/glibc/glibc_2.26.bb: Exception during build_dependencies for do_install
WARNING: /home/lfpm1993/Desktop/openembedded/meta-linaro/meta-ilp32/recipes-overlayed/glibc/glibc_2.26.bb: Error during finalise of /home/lfpm1993/Desktop/openembedded/meta-linaro/meta-ilp32/recipes-overlayed/glibc/glibc_2.26.bb
WARNING: /home/lfpm1993/Desktop/openembedded/meta-linaro/meta-ilp32/recipes-overlayed/glibc/glibc-initial_2.26.bb: Exception during build_dependencies for do_install
WARNING: /home/lfpm1993/Desktop/openembedded/meta-linaro/meta-ilp32/recipes-overlayed/glibc/glibc-initial_2.26.bb: Error during finalise of /home/lfpm1993/Desktop/openembedded/meta-linaro/meta-ilp32/recipes-overlayed/glibc/glibc-initial_2.26.bb
ERROR: ExpansionError during parsing /home/lfpm1993/Desktop/openembedded/meta-linaro/meta-ilp32/recipes-overlayed/glibc/glibc_2.26.bb
Traceback (most recent call last):
bb.data_smart.ExpansionError: Failure expanding variable do_install, expression was 	oe_runmake install_root=/home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image install
	for r in bootparam_prot.x nlm_prot.x rstat.x 	  yppasswd.x klm_prot.x rex.x sm_inter.x mount.x 	  rusers.x spray.x nfs_prot.x rquota.x key_prot.x; do
		h=`echo $r|sed -e's,\.x$,.h,'`
		install -m 0644 /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/git/sunrpc/rpcsvc/$h /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image//usr/include/rpcsvc/
	done
	install -Dm 0644 /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/etc/ld.so.conf /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image//etc/ld.so.conf
	install -d /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/usr/lib/locale
	make -f /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/generate-supported.mk IN="/home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/git/localedata/SUPPORTED" OUT="/home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/SUPPORTED"
	# get rid of some broken files...
	for i in ; do
		sed -i "/$i/d" /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/SUPPORTED
	done
	rm -f /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/etc/rpc
	rm -rf /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/usr/share/zoneinfo
	rm -rf /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/usr/libexec/getconf
	rm -f /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/etc/localtime
	rm -rf /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/var
	# remove empty glibc dir
	if [ -d /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/usr/libexec ]; then
		rmdir --ignore-fail-on-non-empty /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/usr/libexec
	fi
	oe_multilib_header bits/syscall.h bits/long-double.h
	if [ -f /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/usr/bin/mtrace ]; then
		sed -i -e '1s,#!.*perl,#! /usr/bin/env perl,' -e '2s,exec.*perl,exec /usr/bin/env perl,' /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/usr/bin/mtrace
	fi
	rm -rf /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/usr/include/rpcsvc/rquota*
	# Info dir listing isn't interesting at this point so remove it if it exists.
	if [ -e "/home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/usr/share/info/dir" ]; then
		rm -f /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/usr/share/info/dir
	fi
	if ! ${@bb.utils.contains('DISTRO_FEATURES', 'ldconfig', 'true', 'false', d)}; then
		# The distro doesn't want these files so let's not install them
		rm -f /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/etc/ld.so.conf
		rm -f /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/sbin/ldconfig
		# This directory will be empty now so remove it too.
		# But check whether it exists first, since it won't for glibc-initial.
		if [ -d /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/etc ]; then
			rmdir /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/etc
		fi
	fi
	if echo glibc|grep -q "glibc-initial"; then
		return
	fi
	install -d /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/etc/init.d
	install -d /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/var/db/nscd
	install -m 0755 /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/git/nscd/nscd.init /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/etc/init.d/nscd
	install -m 0755 /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/git/nscd/nscd.conf /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/etc/nscd.conf
	sed -i "s%daemon%start-stop-daemon --start --exec%g" /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/etc/init.d/nscd
	install -d /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/lib/systemd/system
	install -m 0644 /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/git/nscd/nscd.service /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/lib/systemd/system/
	if ${@bb.utils.contains('DISTRO_FEATURES', 'systemd', 'true', 'false', d)}; then
		install -d /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/etc/tmpfiles.d
		echo "d /run/nscd 755 root root -" \
			> /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/etc/tmpfiles.d/nscd.conf
	else
		install -d /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/etc/default/volatiles
		echo "d root root 0755 /var/run/nscd none" \
			> /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/etc/default/volatiles/98_nscd
	fi
	if [ "/lib" != "/lib" ] ; then
		# The aarch64 ABI says the dynamic linker -must- be /lib/ld-linux-aarch64[_be].so.1
		if [ -e /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/lib/ld-linux-aarch64.so.1 ]; then
			ln -s ${@base_path_relative('/lib', '/lib')}/ld-linux-aarch64.so.1 \
		elif [ -e /home/lfpm1993/Desktop/openembedded/build/tmp-glibc/work/aarch64-oe-linux/glibc/2.26-r0/image/lib/ld-linux-aarch64_be.so.1 ]; then
			ln -s ${@base_path_relative('/lib', '/lib')}/ld-linux-aarch64_be.so.1 \
		fi
	fi
	do_install_armmultilib
 which triggered exception NameError: name 'base_path_relative' is not defined
The only thing I changed from the original files was that I added "DISTRO_FEATURES_append = " virtualization"" to the /Desktop/openembedded/meta-virtualization/layers.conf. It should be noted, I guess, that I'm running a virtual machine with Ubunto 16.04.1 LTS...executing uname -a gives:
Linux lfpm1993-virtual-machine 4.13.0-39-generic #44~16.04.1-Ubuntu SMP Thu Apr 5 16:43:10 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
What I need from the development board (ARM Versatile Express Juno r2 Development Platform) is the ability to run PAPI (maximize the number os hardware counters that I have avaiable) and the energy aware scheduler (EAS). The reasson I didn't use a prebuilt build was because of ,according to the kernels tab, the only option that allows EAS is `ack-armlt' and all prebuilt configurations that don't use Android have `latest-armlt'.
So, my question is how do I solve those warnings and errors? if the 'base configuration' is correct, that is if I really need to run the addendum B? And in the case, of if it is 'working' what should I be doing next? (hope I was clear, english is not my native language).
Thanks for the help,
Luis Martins
