I am using the DSTREAM and DS-5 to trace the execution on my Juno r1 board. It worked well before. However, i suddenly met an issue that i cannot use the 4G trace buffer inside the DSTREAM. If i choose the DSTREAM trace buffer, clicking the "start capture" button leads to an error "ERROR(ECMD3): Error attempting to start Trace capture device DSTREAM". If i choose the on-chip buffer, everything works well.
I don't know what is the issue. Is there anything wrong with my DSTREAM hardware? Any way to fix or troubleshoot it?
Thanks in advance!
Best Regards,
Zhenyu
Hi Zhenyu,
For DS-5 question you might be better asking the Software Tools Community (or if you have a DS-5 license email suport-sw@arm.com). However...
I've just tested this with my Juno r2 board and DS-5.28 with an ultimate license.
Screenshot attached.
So this seems to work OK for me. If you have an old version of DS-5 making sure you are using the latest versions is always a good first step.
MarkN.
View all questions in Arm Development Platforms forum
