Error in Compiling 64-bit Neon code using Android NDK r10c
          I am trying to compile a 64-bit Neon code using android ndk-r10c in eclipse. I am getting an error message:
Android NDK: NEON support is only possible for armeabi-v7a ABI  its variant armeabi-v7a-hard and x86 ABI
Android NDK: Please add checks against TARGET_ARCH_ABI in jni/Android.mk".
This is my Android.mk file
LOCAL_PATH := $(call my-dir)
include $(CLEAR_VARS)
LOCAL_ARM_MODE := arm
LOCAL_ARM_NEON := true
LOCAL_MODULE := helloneon
LOCAL_SRC_FILES := helloneon.c
ifeq ($(TARGET_ARCH_ABI),$(filter $(TARGET_ARCH_ABI), arm64-v8a))
    LOCAL_CFLAGS := -DHAVE_NEON=1
ifeq ($(TARGET_ARCH_ABI),x86)
    LOCAL_CFLAGS += -mssse3
endif
    LOCAL_SRC_FILES += helloneon-intrinsics.c.neon
endif
LOCAL_STATIC_LIBRARIES := cpufeatures
LOCAL_LDLIBS := -llog
include $(BUILD_SHARED_LIBRARY)
$(call import-module,cpufeatures)
Can anyone help me in resolving this?
Thanks and Regards
Parvathy
  • This isn't so much an error as it is the NDK giving you a very stern warning and aborting. It is actually giving you the solution in the warning though. The stock Android.mk file included in android-ndk-r10c/samples/hello-neon/jni does not have these two lines:
    The second item "LOCAL_ARM_NEON := true" is causing your warning because you are using it outside of your ABI check. You should have your ABIs defined in "Application.mk", something like this:
    APP_ABI := armeabi armeabi-v7a arm64-v8a x86
    Then when you do the "ifeq ($(TARGET_ARCH_ABI),$(filter $(TARGET_ARCH_ABI), armeabi-v7a x86))" check, it is safe to set LOCAL_ARM_NEON to true
    Try moving those two lines you've added inside the ABI check and it should compile but they are redundant since you are already defining the abi's and adding the NEON cflag...
    In practice it is safe to force your module to build a version with NEON and one without so long as you're doing runtime detection as described in: android-ndk-r10c/docs/Programmers_Guide/html/md_3__key__topics__c_p_u__support__c_p_u-_a_r_m-_n_e_o_n.html
  • try this:
        LOCAL_CPPFLAGS  += -mssse3
        LOCAL_CXXFLAGS  += -mssse3
    endif
    ifeq ($(TARGET_ARCH_ABI),arm64-v8a)
        LOCAL_CFLAGS    += -DHAVE_NEON64_or_Some_Other_flag =1
        LOCAL_CPPFLAGS  += -DHAVE_NEON64_or_Some_Other_flag=1
        LOCAL_CXXFLAGS  += -DHAVE_NEON64_or_Some_Other_flag=1
    endif
    ifeq ($(TARGET_ARCH_ABI),armeabi-v7a)
        LOCAL_CFLAGS    += -mfpu=neon
        LOCAL_CPPFLAGS  += -mfpu=neon
        LOCAL_CXXFLAGS  += -mfpu=neon
    endif
    ifeq ($(TARGET_ARCH_ABI),armeabi)
        #some fetchers for this arch
    endif
