On a Get Start thread of this web site, it has a short NE10 example having such snippet:
I install NE10 library. In the documentation, it has a different definition:
ne10_result_t ne10_addc_float_neon (ne10_float32_t *dst, ne10_float32_t *src, const ne10_float32_t cst, ne10_uint32_t count) asm("ne10_addc_float_neon")
I am curious about the last "asm("ne10_addc_float_neon")". Could you tell me that?
Thanks,
Hi, Ruwan2,
>Hi,
These 2 functions are different functions, but they have same functionality. Generally, the difference is: ne10_addc_float_c is implemented in C and ne10_addc_float_neon is implemented by assembly and optimized by Neon.
the asm() key word is used to specify the name in generated object file. It is a C extension. You can refer more details at http://gcc.gnu.org/onlinedocs/gcc-4.8.2/gcc/Asm-Labels.html#Asm-Labels.
>Thanks,
View all questions in Android forum
