Well... I can tell you for sure that ARM has not created any Cortex-A10.Then, there might be a bit of loose use of the term "processor". In tablets, you would rarely find a processor as such, but a System on Chip (SoC). A SoC would include a processor but not only that; the full system with controllers, graphic processor (GPU)... It's still a chip containing processors.Allwinner A10 SoC has several "cores" in the sense that it features an ARM Cortex-A8 CPU and an ARM Mali-400 GPU, it has a single "CPU core" though.The only difference I could see with your Quadrant result would be the clock speed. However, I don't know how Quadrant came up with that value. As you can find other manufacturers mentioning 1.5GHz from that SoC, I would tend to think it is possible, however I cannot confirm for your chip/device.Cheers,Alban
View all questions in Android forum
