hi,
I was able to run JNI Opencl kernel on my mali T830 by coping the system/vendor/lib/libGLES_mali.so and libOpenCL.so to the JNI folder on android studio. of course we to load some library through
System.loadLibrary(xxx).I hace done the same with my mali G72. Compilation and linkage are fine. But in excecution time i am asked for two other library :
system/vendor/lib/libgpucommon_vendor_client.so and system/vendor/lib/libmediacomm@2.0-client.sothe problem is taht android do not copy the libmediacomm@2.0-client.so to the data/data/apk/lib. So at run time a got this error : java.lang.UnsatisfiedLinkError: dlopen failed: library "libmediacomm@2.0-client.so" not foundIt is possible to get library which does not need of the system/vendor/lib/libgpucommon_vendor_client.so and system/vendor/lib/libmediacomm@2.0-client.so.Or if you know how to run openCL on android 9 (honnor play) whitout linker library problem. thanks a lot for drive me to a succefull solution.regards herve terrole, paris france. ;))
Ok ! i found why libmediacomm@2.0-client.so is not copied to /data/data/apk/lib.
the problem is that the labrary containt the "@" caracter in the name. You can easely test it under android studio. just create a JNIlibrary and check data/data/apk/lib.
test in android.mk
LOCAL_MODULE := JNIProcessor@2.0-clientLOCAL_SRC_FILES := processor.cppand
LOCAL_MODULE := JNIProcessor2.0-clientLOCAL_SRC_FILES := processor.cpp
and you will find out.So as the library is directly called from data/data/apk/lib. I need to change library name inside libGLES_mali.so and rename the
libmediacomm@2.0-client.so to libmediacomm2.0-client.so. But how do i change the lib name inside libGLES_mali.so ?
So the problem is solve for you. Can you help me to solve mine ;))PS: i bougth the honnor play two days ago only for testing OpenCL on 12 heart G72 gpu. It is a petty to spend monney for nothing. ;))thanks for you help.
regards herve terrolle from paris, France.
View all questions in Android forum
