Android 9 Mali G72 OpenCL library for C++ build
hi,
I was able to run JNI Opencl kernel on my mali T830 by coping the system/vendor/lib/libGLES_mali.so and libOpenCL.so to the JNI folder on android studio. of course we to load some library through
System.loadLibrary(xxx).
I hace done the same with my mali G72. Compilation and linkage are fine. But in excecution time i am asked for two other library :
system/vendor/lib/libgpucommon_vendor_client.so  and system/vendor/lib/libmediacomm@2.0-client.so
the problem is taht android do not copy the libmediacomm@2.0-client.so to the data/data/apk/lib. So at run time a got this error :
java.lang.UnsatisfiedLinkError: dlopen failed: library "libmediacomm@2.0-client.so" not found
It is possible to get library which does not need of the system/vendor/lib/libgpucommon_vendor_client.so and system/vendor/lib/libmediacomm@2.0-client.so.
Or if you know how to run openCL on android 9 (honnor play) whitout linker library problem.
thanks a lot for drive me to a succefull solution.
regards herve terrole, paris france. ;))
  • Hi,
    Ok ! i found why libmediacomm@2.0-client.so is not copied to /data/data/apk/lib.
    the problem is that the labrary containt the "@" caracter in the name. You can easely test it under android studio. just create a JNIlibrary and check data/data/apk/lib.
    test in android.mk
    LOCAL_MODULE := JNIProcessor@2.0-client
    LOCAL_SRC_FILES := processor.cpp
    and
    LOCAL_MODULE := JNIProcessor2.0-client
    and you will find out.
    So as the library is directly called from data/data/apk/lib. I need to change library name inside libGLES_mali.so and rename the
    libmediacomm@2.0-client.so to libmediacomm2.0-client.so. But how do i change the lib name inside libGLES_mali.so ?
    So the problem is solve for you. Can you help me to solve mine ;))
    PS: i bougth the honnor play two days ago only for testing OpenCL on 12 heart G72 gpu. It is a petty to spend monney for nothing. ;))
    thanks for you help.
    regards herve terrolle from paris, France.
  • Hi,
    test in android.mk
    and
