Site
Search
User
Site
Search
User
Groups
Arm Research
DesignStart
Education Hub
Graphics and Gaming
High Performance Computing
Innovation
Multimedia
Open Source Software and Platforms
Physical
Processors
Security
System
Software Tools
TrustZone for Armv8-M
中文社区
Blog
Announcements
Artificial Intelligence
Automotive
Healthcare
HPC
Infrastructure
Innovation
Internet of Things
Machine Learning
Mobile
Smart Homes
Wearables
Forums
All developer forums
IP Product forums
Tool & Software forums
Pelion IoT Platform
Support
Open a support case
Documentation
Downloads
Training
Arm Approved program
Arm Design Reviews
Community Help
More
Cancel
Developer Community
Tools and Software
Jump...
Cancel
Android forum
Hardware suggestion to work on TrustZone in Android
Android blog
Forums
Help
Jump...
Cancel
New
Replies
Subscribers
3 subscribers
Views
Users
0 members are here
Android
Address
Documentation
Arm11
Cortex-A
Cortex-A8
TrustZone
Development Boards
Interrupt
Related
Offline
Alberto Maria Scattolo
over 7 years ago
Note: This was originally posted on 29th August 2011 at
http://forums.arm.com
Hi everybody,
For my MSc thesis I have to work on ARM TrustZone and the idea is to use it in Android OS (2.3+). I'm pretty new to this world but reading the forum and the documentation I understand that a dev board (or even a consumer device) powered by a TrustZone capable CPU (Cortex A15, A9, A8, A5 and ARM1176) is not enough to work on TrustZone since it would also requre to have a Protection Controller, an Address Space Controller and a TrustZone "aware" interrupt controller.
So, as fas as I can understand, I think that devices like Google Nexus S, which is powered by a Samsung Hummingbird Cortex-A8, will not guarantee that I can actually work with TrustZone.
- Does this mean I have to use a development board?
- Only development boards by
ARM
? I've never used a dev board but I see there are a lot of dev board manufacturers.
- Do you have any board to suggest me as candidate for the project? I must work on TrustZone but I also need to run Android.
Thank a lot for you help.
Bests,
Alberto
Offline
Martin Weidmann
over 7 years ago
Note: This was originally posted on 31st August 2011 at
All Cortex-A based devices will have some level of TrustZone support. But if you want to do something useful you'll need one with a proper TrustZone aware memory system. In some cases this is present, but not accessible (e.g. the Beagle board). The Versatile Express A9 board from ARM does have a TZ aware memory system, but might be a bit pricey. Your best bet might be to ping the board vendors - specifying that you want to run code in both Normal and Secure world.
Cancel
Up
0
Down
Cancel
Offline
over 7 years ago
Thank you so much ttfn! I will also ask for Android support, just to be sure.
Thanks once again!
Cancel
Up
0
Down
Cancel
Offline
jdbtx jdbtx
over 7 years ago
Along these same lines but probably an even more basic question. If I refer back to the ARM V7 Architecture Reference to the description of the Security Extensions, they are described as being "Implementation Dependent". When I look at one of the specific reference manuals for the processors mentioned above ( Cortex A8, A9, etc.) there doesn't seem to be any doubt that they are there. My initial interpretation was that it would be up to one of the ARM partners actually implemeting one of the above as to whether or not they wanted to include them. Now I'm thinking the that it actually means the particular design within the ARM v7 portfolio. In other words, if someone realizes a Cortex-A8 design, it will have the security extensions. True?
Thanks.
Cancel
Up
0
Down
Cancel
Offline
Peter Harris
over 7 years ago
Note: This was originally posted on 1st September 2011 at
Yes. To date all of the ARM Cortex-A family implement the security extensions; implementations from other companies with an architecture license can choose to implement them, or not.
As per TTFN's comment, it's not just about the processor though. The memory system around the processor must also be implemented to take advantage of the extra security signalling generated by the core extensions; it is possible to have a Cortex-A core in a SoC with no security benefits at all if the memory system isn't using the extra bus signalling to partition resources.
Cancel
Up
0
Down
Cancel
Offline
over 7 years ago
Dear isogen74,
Thank a lot for your reply. Is there any way to understand if the memory system the extra bus signaling? I've read lots of board datasheets from many manufacturers but nobody seems to underline this aspect (and even writing to the their tech support does not help). Talking about ARM dev board, is there anything specific to look for?
Thank you so much.
Alberto
Cancel
Up
0
Down
Cancel
Offline
Martin Weidmann
over 7 years ago
In the datasheets you could look out for components like TZPC (TrustZone Protection Controller), TZSAC (TrustZone Address Space Controller) or TZIMW (TrustZone Memory Wrapper). These are the kind of things you'd expect to see in a system that had a TZ aware memory system. As an example, here is the page from the Versatile Express board manual that covers one of the TZ peripherals -->
http://infocenter.arm.com/help/topic/com.arm.doc.dui0448e/CHDHFEHG.html
Cancel
Up
0
Down
Cancel
Offline
over 7 years ago
Thanks a lot ttfn! Checking the reference manuals it turns out that only two dev board fully support TrustZone:
- Versatile Express CoreTile Express A9x4 (V2P-CA9) -->
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0448e/CHDHFEHG.html
- RealView Platform Baseboard for ARM1176JZF-S (PB1176JZF-S) -->
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0425f/Ciabdfhj.html
Now it's time to understand if these boards will run Android! Any suggestion? On Versatile Express family board it says they can run a desktop OS like Linux.
Cancel
Up
0
Down
Cancel
Offline
Peter Harris
over 7 years ago
The Versatile Express with A9x4 core tile does run Android.
See
http://linux-arm.org/LinuxKernel/LinuxAndroidPlatform
Iso
Cancel
Up
0
Down
Cancel
Offline
over 7 years ago
Thanks Iso. Any idea about the PB1176JZF-S?
Cancel
Up
0
Down
Cancel
Offline
over 7 years ago
According to this (
http://www.arm.com/community/software-enablement/google/index.php?tab=Related+Products
) Android should run
Cancel
Up
0
Down
Cancel
Offline
suresh gopal
over 7 years ago
Note: This was originally posted on 26th May 2012 at
For a project on ARM trustzone , the ARM-fastmodels ,which supports TRUSTZONE, can be used.
ARM fastmodels are emulators. These fastmodels can be downloaded directly from the ARM website itself.
For a starter, one can look into the open source trustzone software provided by the company named
Sierraware
, which is available at
http://openvirtualization.org/
The site also provides complete information for downloading and installing fastmodel.
Cancel
Up
0
Down
Cancel
By title
By date
By reply count
By view count
By most asked
By votes
By quality
Descending
Ascending
All recent questions
Unread questions
Questions you've participated in
Questions you've asked
Unanswered questions
Answered questions
Questions with suggested answers
Questions with no replies
Answered
Crash while linking shader program
0
5274
views
3
replies
Latest
over 1 year ago
by
Andy Neil
Not Answered
Tracking down a crash while linking a shader
0
3411
views
0
replies
Started
over 1 year ago
by
Martin Bell
Not Answered
Detect number of cores?
0
3415
views
0
replies
Started
over 1 year ago
by
Howls
Not Answered
Want suggestions for quiz writing about a mobile app development framework
0
3388
views
0
replies
Started
over 1 year ago
by
varsha solanki
Suggested Answer
Mali Graphic Debugger can not work on Android 8.0
0
ETM
Android
Mali Graphics Debugger
Linux
5539
views
2
replies
Latest
over 1 year ago
by
Peter Harris
View all questions in Android forum
