map license
When trying to run map i get the following:
Waiting for licence
Arm Forge 21.0 - Arm MAP
MAP: Your current licence (12827) does not permit as many processes as you requested.
MAP: Requested Processes: 5
MAP: Available Processes: 1
MAP: Please contact the Arm Forge support team if you wish to profile more processes.
It runs fine on a single process, but not on multiple.
How do I run this on more than one process? I would expect that a single license seat is all that should be required to run a parallel job, not seats=num of processes.
Is this an error?
  • Hi,
    Thank you for the question. According to our records licence 12827 has "max_processes=1" which explicitly means you can't request more than one process per session.
    You'd need a licence upgrade, I'd advise you speak with your sys admins. Unfortunately you won't be able to debug more than 1 process with this licence.
  • Hi,
There are no posts to show. This could be because there are no posts in this forum or due to a filter.
