Hi
As part of my MSc Scientific Computing at UCL, I'm benchmarking a small Raspberry Pi 4 Model B cluster.
I would like to reference the theoretical maximum performance of the BCM2711 (4 x ARM Cortex-A72) in Linpack terminology, R_peak.
I believe R_peak to be: 1.5 GHz x 3-way dispatch x 4 cores = 18 Gflops. This seems to be the "standard" Linpack methodology.
It would be very helpful if someone more knowledgable than me can confirm that this seems reasonable. Or even better, if there is some official ARM benchmarking material which I can reference in my dissertation?
Best wishes
John
Thank you again Chris.
Hi.
I think the easiest way to imagine this is that the core has the option to use two 64-bit pipelines or combine them together as a single 128-bit vector. If you look at the throughput numbers in the document you reference hopefully that explains those away a bit more.
Chris
Hi Chris
Thank you. That is very helpful!
If you don't mind a follow up question...
On Page 6 of the Cortex-A72 Software Optimisation Guide, 2.1 Pipeline Overview, the block diagram, and subsequent instruction details, refer to two floating point pipelines, FP/ASIMD 0 and FP/ASIMD 1. I'm not sure how these relate to "a single 128-bit vector pipeline"?
Kind regards
Hi John,
An A72 core has a single 128-bit vector pipeline. This can therefore do two double precision FLOPs per cycle, such as are used in High Performance Linpack. The use of FMA instructions (multiply and add) means every cycle you can do 2 FLOPs on 2 doubles, i.e. 4FLOPs. At 1.5GHz you therefore have a maximum performance per core of 6GFLOPs. This gives a peak performance for 4 cores of 24 GFLOPs.
Hope this helps.
View all questions in HPC forum
