Why MGD always tells Root Interceptor Needs update?
Mgd 4.9.0
Device: Huawei Mate10
Android: 8.0
In Device Manager, I have installed MGD Android App and Root Interceptor,
after device reboot, Device Manager always tell that Root Interceptor " Needs update", If i click the update button,
it will install the components success and reboot, but again "Needs update",  whatever how much times I followed the update button.
And I can't get any trace data.
And I found the libGLES_mgd.so is installed to the /vendor/lib/egl and /vendor/lib64/egl directory.
Don't known how to solve this problem.
  • Hello,
    We have had reports of symbolic links not working on Huawei Mate 10.
    You can try deleting the libGLES.so and libGLES files (which are symbolic links), then doing a hard copy of the MGD interceptor library (libGLES_mgd.so).
    e.g.
    rm /system/lib/egl/libGLES.so
    cp /system/lib/egl/libGLES_mgd.so /system/lib/egl/libGLES.so
    The User Guide section "Target Installation -> Android -> Rooted Android" explains where MGD is installed. You will need to update all of the interceptor library locations.
    If that doesn't work, could you try to trace a device, and share with me the logcat output?
    Kind regards,
    Liam
  • Hello,
    e.g.
    Kind regards,
    Liam
